Post new thread Reply to topic  [ 16 posts ]  Go to page 1, 2  Next
 Post subject: How we roll. (Suspension setups)
New postPosted: Wed Dec 10, 2008 1:22 pm
I would like to make a stickie for guys to see how we are running our suspension. I would like you guys to post in here but NO WHORING PLEASE. I will move them to chronological order according to year as we go along. Here is how I would like you to post.
Year, Make, Model
Front suspension
Spindle or arms or stock
Kit if used
Bag size
Basically how you did the front
Rear suspension
Link type or leafs pulled however you did it
Type of joints
Notch size
Bag size
Body drop
amount of drop
stock floor, traditional or other
Air management
Valves size, number and brand
Air line size
Tank size and number
Compressor type, brand, size and number
Wheel and tire size.
List if inside duals are different
What you would change or do different
Self explanatory
Post a picture preferably one side shot.
Post a link to your garage.
Post a link to a build thread or thread about your vehicle if there is one.
Thanks guys. This should help the new guys out, and probably some of the og's.
And it's not just for bagged trucks also static and lifted.
New postPosted: Wed Dec 10, 2008 5:43 pm
67730
'77 GMC C30
Western Chassis 6/8-but it's more like 6/10-ish
Front:
3" Drop Spindle
3" Drop Coil
stock shocks
Rear:
Flip Kit
2" Shackle
shorter shocks (sorry, no P.N.)
Wheel/Tire Size:
16" stockers
(6) 225/75/16
The kit's pretty self-explanatory. Went on with minimal headaches. Western Chassis/Sport Truck Direct were real easy to deal with. I ended up removing the inner fenders and cutting a small hole in my bed to clear the pumpkin. I suspect if I didn't run the drop shackles, I wouldn't have had to cut the bed, but there ain't no getting around the inner fenders with this amount of drop. You're going to rub up front. A mini-tub would have been sufficient, but I opted to just yank them out entirely.
It's a real streetable drop. I use it as my daily so it get a lot of miles put on it. I haven't had any problems since I yanked the inners and cut the bed.
I'll definitely run this drop again on my next rig. Although next time, I think I'll run some helper bags as well.
*UPDATE* I raised the rear end up an inch on the shackles while I had the bed off. It kept me from having to cut a hole in my new bed. So far, so good.
Build thread
 Post subject: Re: How we roll. (Suspension setups)
New postPosted: Wed Dec 10, 2008 10:59 pm
1999 Chevrolet crew cab
11840
Year, Make, Model
1999 Chevy C3500
Front suspension
Belltech spindles, SlamSpecialties 8" bags,cups from Suicide Doors
Rear suspension
Parrallel 4-link, panhard, 8" Slam Specialties bags behind axel,step notch
Body drop
none
Air management
8 SMC 1/2" valves, line, fittings, AVS 9 rocker style lockable switchbox,Engine driven compressor kit, 2 Stainless 5 gallon tanks, and one 300 series nitrogen bottle for backup.
16s w/ 225/75/16
Switch my dump valves to GC stealth valves
EC_Dually
New postPosted: Thu Dec 11, 2008 8:10 am
2000 Chevrolet Crew Cab Dually
13550
Year, Make, Model
2000 chevy crew cab dually
Front suspension
Chassis Tech 3 inch spindels
slam re8 bags
suicide doors cups
Rear suspension
custom made 2 link
slam re8 bags
suicide door brakets for bags on bars
custom crossbar to tie link bars together ( temp)
10 in monster notch
Body drop
no body drop planned
Air management
6 GE XTREEM 1/2 VALVES
1/2 inch line
2 switches
bigg ass nitrogen tank
16 inch aloca small holes
225/60/16
same size
sand down and smooth out and reapaint,
22" semi's
shaved door handles
suicide back doors
sheet metal bed
redo whole interior
removed tie bar on links and add Watts Link
DRAG DRAG DRAG DRAG DRAG DRAG DRAG DRAG...
LONG LIVE THE SHITBOXES...Image
RHMdually
New postPosted: Thu Dec 11, 2008 11:03 pm
1993 Chevrolet Crew Cab Dually
4950
Year, Make, Model
1993 chevy dually
Front suspension
stock arms, belltech spindles, re-7 bags, custom cups
Rear suspension
triangulated 4 link, bag on bar, re-8s, 6 inch or so notch
Body drop
4 inch stock floor
Air management
8 smc 3/8ths valves, 1/2inch line, 8 gallon tank, dc5000 compressor
19s with a 235/35/r19 16 inners, cant remember the size
already redid it to fix everything i would do different lol
BONDO
New postPosted: Fri Dec 12, 2008 12:19 am
190
1975 Gmc C-20
still 8 lug
up front- stock arms, aim spindles, extensive cups
rear- 8 inch notch, suicide triangulated 4-link, djm shock all around
dominator 8 bags 2600's
2 480 compressors
2 5 gallon tanks
1/2 dot line, soon to be copper
4 1/2 valves
16 inch steel black rims
3 inch lug nuts
205 60 16's
lays frame hard
cant a fat white man with a job and kids have a lowrider too?
New postPosted: Mon Jan 12, 2009 1:08 pm
67730
Bumpage...
New postPosted: Mon Jan 12, 2009 1:29 pm
72500
Year, Make, Model
1998 Gmc 3500 Crewcab Longbed Nnon dually
Engine
7.4Liter 454c.i. kept a/c
Front suspension
DJM spindles KustomWorks Upper/Lower A Arms
Slam Specialties RE-7's up front and Re-7s in the rear
Rear suspension
Bag over axle
4linked
Notch intergrated into stockfloored frame
Stockfloored bodydrop
Air management
8 GC extremes 1/2 250 PSI no hoppin here
1/2 line
12 gallon tank mounted in rear
oasis hp1000 compressor
22x9 Panther Juice 8's
Nexen 245 40 22 tires
Fuel cell from Guilty By desgins(aka Kyle)
Not sure yet
Stocker
Shocker
New postPosted: Mon Jan 12, 2009 1:31 pm
You guys kinda missed the point on what you would change. I just meant with your suspension setup. And lets us know why you don't like something if you would change it.
sick82
New postPosted: Mon Jan 12, 2009 7:06 pm
2650
Year, Make, Model
2007
gmc
sierra 3500
Front suspension
re8's
djm upperand lower arms
bought suicide doors 1/4 bridge brackets. weld'd it to the frame. gussetted the shit out of it.
Rear suspension
custom 2 link out of 2x2x1/4
suicide doors 3 inch bushings
bags behinde the axel
goodyear 2b12-406 semi bags
Body drop
none.....YET
Air management
6 smc 3/8ths valves.
1/2" dot line
10 gallons of air
200psi
2 viar 380's
avs black 7 rocker switch box.
22's with 265/40/22 toyo's townastys on the rear and stock 16's on the insides with 10 ply toyo's (dont remeber the size off hand) but its that stock size that came on the truck.
mcgaughys spindles and ekstensive control arms and move the upper control arm mount. (may do it when and if i stockfloor it)
viewtopic.php?f=6&t=4047
josh
ChopperDave
 Post subject: Re:
New postPosted: Sat Apr 25, 2009 1:10 pm
1988 Chevrolet R30 crew cab
870
Campy, was there any instructions or templates?
OneFastHoagie
New postPosted: Sat Apr 25, 2009 2:23 pm
1988 Chevrolet ext. cab dually
17270
Year, Make, Model
1988 chevy ext cab dually
Front suspension
3 inch beltech front spindles
re7 bags. lays hard on front crossmember
Rear suspension
Pulled helper leaf, flip kit and 1 inch blocks
re5's helper bags mounted to leafs
mini like 2 inch c notch
Body drop
zip
Air management
4 smc 3/8th's (one each for all downs) 4 asrco (i think lol) 1/2 valves for the ups.
1/2 inch lines
2 tanks. one 7 gal and one unknown, looks like a 4 gal?
2 viaair's, one 380 and one 480 150 psi
16 inch alcoa OG 5 stars.
i can't remember thease things lol.
maybe some shocks on the front? i'll get to it one day.
R.I.P Big Avatar you'll be missed, but never replaced!
Low95xlt: hoagie ur teh man, man OG for life
Don't whore my meaningfull posts or your name will be here.
PigRig and Low95xlt have once again whored my thread looking for help!!
New postPosted: Thu Mar 11, 2010 1:41 pm
1986 Chevrolet Crew Cab Dually
5180
1986 Crew Cab Big Block Square 6/10
Front: Western Chassis 3in. springs + 3 in. Belltech drop spindles with nitro drop shocks and custom tubs
removed bump stops and metal stands for bump stops
Rear: DJM 2" drop shackles, custom flip kit for C&C rear, step notch, relocated shocks, nitro drop shocks, custom tubs.
Western Chassis flip kit does not work with a square body C&C rear, a custom flip kit had to be made. Pulled overload leaves for smoother ride.
31.5 in. tall tires at the rear
29.4 in. tall tires at the front
Wouldn't change anything except bigger tires up front.
More pics @-
http://duallyscene.com/forums/post78234.html#p78234" target="_blank
'86 Crew Cab FBO BBC,TH400 G/V O/D Equipped, Built C&C, 6/10 on 24's
Last edited by WIDE LOAD C-30 on Sun Apr 03, 2011 7:05 pm, edited 2 times in total.
sigs1ton
New postPosted: Wed Mar 16, 2011 10:39 am
1997 Chevrolet Crew Cab Dually
560
Can we get somemore static dropped guys to put there info up? :D
I'm all grown up and still play with cars.
New postPosted: Thu Oct 27, 2011 1:29 pm
nice info here , looks to me like slam RE7 and 8 bags rule when it comes to airride
hows the ride comfort and wat pressure are you running in the bags i seen one running at 250 bar tankpressure , seems on the edge of the maximum pressure in a propane tank i want to use for airstorage
No new posts How to get from a 2/4 to a 5/7?
think2x
646
Wed Jan 12, 2011 7:56 pm
think2x View the latest post
No new posts Attachment(s) How can I install my air bags?
yellowGT
27
1708
Mon Jan 03, 2011 10:31 am
No new posts how do i drop my dodge???
AnT
870
Thu Jan 20, 2011 5:02 am
Dat Dood View the latest post
No new posts Need info on how many coils to cut ( yeah I tried the search
RunninLo
627
Sun Aug 02, 2009 12:36 am
reppinswapeam View the latest post
No new posts How much can I get for my Air bag set up - the compressors?
TheWebWheeler
428
Fri May 08, 2009 11:12 pm
TheWebWheeler View the latest post
New posts View first unread post Attachment(s) How we roll. (Suspension setups)
15
7619
Thu Oct 27, 2011 6:53 pm
circuitguy View the latest post
No new posts How to keep you pinion right with a 2-link
25
1085
Sun Dec 21, 2008 11:14 pm
gkrew View the latest post
No new posts How much drop and clear 22's?
03on22s
590
Fri Sep 12, 2008 2:57 pm
03on22s View the latest post
No new posts How much do I need to Z my frame?
speedracer
630
Fri Aug 22, 2008 6:43 pm
NUKLHEADTATTOO View the latest post
No new posts anyone know how to make a 83 nissan lay?
277
Mon Aug 11, 2008 12:07 pm
