Post new thread Reply to topic  [ 4 posts ]
temporaptor
 Post subject: Bag set up questions?
New postPosted: Wed Sep 08, 2010 6:58 am
200
I have a 1999 C3500 4 door long bed Non Dually that im in the process of bagging, well collecting parts lol. It started out lifted and now i am back to stock wheels and a flip kit in the back. My goals for this truck is to put 20 inch rims and low pro tires and get it as low as possible but I do not want it to lay out all the way. I want to be super low all the way aired out but not scrape on a flat surface. So should i run stock spindles or 3" drop spindles up front? I'm Gonna run slam RE 7 up front, and gonna build a link for the back with Suicidedoors.com parts and RE 8s. With the flip kit on the back the axle hits the frame pretty easy, will a bolt on C notch have enough travel with the flip kit to not hit? or will I have to weld one in? I would really like to not cut my bed up, I use it all the time to put tools and other gear. But the pumkin looks too close, and i dont even have a notch yet.
Ive had an S10 in the past that laid frame and was all cut out and was really fun but always missed my lack of bed space. Parts i already have are Nitrogen bottle with Reg., and 4 SMC 1/2" valves. Im gonna do the front first and C notch, then rims and tires, Then rear link setup.
I would appreciate any recommendations any of you might have.
Thanks
 Post subject: Re: Bag set up questions?
New postPosted: Wed Sep 08, 2010 9:17 am
49130
If you want it as low as possible and also have it bagged the best option for you would be to buy a 5/7 lowering kit and then just install a simple air ride system. These kits come with the bolt on notches to keep your bed floor stock (pumpkin will be 1" from or even rub the bottom of the bed floor at times). Since you are not wanting to cut the bed floor it is really pointless to build a link system for the rear because you can achieve the same stance with your stock springs and a flip kit. Then you can just make a simple helper bag system for the rear of the truck.
New postPosted: Wed Sep 08, 2010 4:45 pm
72370
i ahve the same truck but im bagged and bodied over 22.. ru na re8 up front and rear...
h2omelon
New postPosted: Wed Sep 08, 2010 9:05 pm
1997 Chevrolet 3500
2250
My truck has the drop like lockone was talking about with a bolt in notch. I have helper bags in the rear also. Without air in the bags I bottom out in the notch. You are definately going to want to go lower. Go ahead and cut it and weld in a notch cover so you can still use your bed.
No new posts Front bag set up on a square body
Bagged Dually
308
Sun Dec 18, 2011 10:04 pm
short1 View the latest post
No new posts bagging the front of my 04 duramax dually
0-psi
14
589
Mon Dec 19, 2011 8:24 am
scatter View the latest post
No new posts I need some control arm help after bagging.
cochino12
316
Fri Nov 18, 2011 12:34 pm
bk2life View the latest post
No new posts Bag and Link Help
artsar
149
Thu Oct 20, 2011 4:34 pm
artsar View the latest post
No new posts Rear bag location for 88 c3500
devastator88
460
Wed Oct 19, 2011 10:27 pm
No new posts Bags over Bar on Parallel 4 link?
IndeliblyInkd
168
Mon Oct 10, 2011 7:05 am
IndeliblyInkd View the latest post
No new posts What kindf of control arms are you guys running on your bagged duallys with semis?
PsychobillyDually
245
Tue Sep 27, 2011 11:34 pm
PsychobillyDually View the latest post
No new posts rear bag ?
226
Sun Aug 28, 2011 5:30 pm
Giovanni View the latest post
No new posts bags for towing?
dailydriven
16
781
Fri Aug 19, 2011 11:26 am
crewcab View the latest post
No new posts helper bags ?
133
Thu Aug 11, 2011 9:25 am
