Post new thread Reply to topic  [ 362 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6 ... 25  Next
 Post subject: Re: 77 CC squarebody build thread..progress!
New postPosted: Mon Aug 02, 2010 11:05 am
49130
Nice progress.
sparkys-crewcab
New postPosted: Wed Aug 25, 2010 3:37 pm
1977 GMC sierra 3500
5350
thanks lock..
i dropped both frame horns yesterday. welded in some 1/4 thick spiderweb gussets. its coming together slowly
h2omelon
New postPosted: Wed Aug 25, 2010 5:37 pm
1997 Chevrolet 3500
2250
Looking good
98crewcabBB
New postPosted: Sat Sep 04, 2010 11:07 am
330
thats it....inspired. heading out to fire up the plasma..........
looking great man, nice clean work!
sparkys-crewcab
New postPosted: Tue Sep 07, 2010 8:23 am
5350
get out there and chop it up!..just make sure to measure a bunch of times before you cut. or you wont be happy with yourself..
originally i bought a used plasma, but it would only cut very thin sheet metal..booo! put it back on craiglslist...
my frame has been shaped the old fashioned way with grinding wheels and a sawsall . (95% with a grinder) oh yea, and a lincoln 225 arc welder (i love that thing) it will give you a sunburn in 30 seconds flat. who needs a tanning bed...lmao
i killed the first harbor freight 4 1/2 inch grinder i bought when i started all this. it started making a funny sound and sparks started flying out of the motor vents. the cord caught on fire. sparks were shooting out of it...i would say it's done with its grinding career. :lol: at least they only cost 20 bucks
sparkys-crewcab
New postPosted: Thu Oct 07, 2010 10:35 pm
5350
i finally got the engine/trans set in the frame to set up everything.(exhaust,driveshaft,trans crossmember)
the trans member bolts to some 1/4 steel angle mounts that are welded to the frame... a little more measuring and the carrier bearing mount will be ready to be welded in..oh, i still have to clearance the trans mount to give some wiggle room for the 3 inch exhaust
good news is my header flanges are not going to hit the ground when laid out. they are even with the bottom of the frame. the catalytic converters are the same way. at least nothing will be hanging down past the frame. :)
more pics!
found a good deal on a brand new red prothane polyurethane trans mount..10 bucks on ebay.. :lol:
New postPosted: Thu Oct 07, 2010 10:57 pm
66750
sparkys-crewcab wrote:
...the catalytic converters are the same way...
You have cats on yours? Weird. My '77 doesn't have 'em.
~Campy…Mr. Campbell if you're nasty.
GM stopped building great trucks in '91.
sparkys-crewcab
New postPosted: Fri Oct 08, 2010 10:10 am
5350
tennessee makes you puts cats on anything that is 1974 and newer. ( i think that is the year) they used to let all 1 ton trucks be exempt until they changed that rule as well. they want everybody to pass emissions around here...lol
i wish i didn't have to use them . they just get in the way. and of course i will have to buy a new one to replace one of them. somehow the honeycomb inside the cat got busted up . they were brand new... :evil:
mazdawg(Mikey)
New postPosted: Wed Oct 13, 2010 2:43 pm
150
Good build soo far man. Frame is looking super clean. Those frame horns don't need any more bracing?
sparkys-crewcab
New postPosted: Thu Oct 14, 2010 5:33 pm
5350
thanks mazdawg...
if i have enough room, i may throw a gusset on top of the frame horns . i need to test fit the front clip to see if the radiator is going to hit anything.
i did measured the distance from the front cab mount, to the bottom support of the radiator to make sure i had room to fit the radiator (before i cut the frame horns off ) . it is going to be a really close fit....
Last edited by sparkys-crewcab on Sat Oct 22, 2011 9:59 am, edited 2 times in total.
mazdawg(Mikey)
New postPosted: Sat Oct 16, 2010 10:34 pm
150
I gotcha that makes sense. Can't wait to see more progress. This really makes me want to get a dually. Still trying to talk the wife into letting me buy one so I can pull my mazda to shows.
sparkys-crewcab
New postPosted: Wed Oct 20, 2010 12:34 am
5350
i pulled the motor/trans back out . threw the rear end back under the frame. and set the cab on to make sure it fit .( all of this work was done by myself. no help at all)
the trans tunnel is going to get cut out and raised next. along with shaving the ac/heater box,fan motor. plus a whole list of other things to do to it...
pics!
i thought this was cool...it still has the original build sheet glued to the rear floorboard. the truck came factory with a smallblock 350 4brl carb. not a 454.
4.10 gear, 10,000# camper special. 400 turbo transmission..
made in baltimore maryland. sold to c r dudley motors in paragould arkansas.( i bought it in jonesboro arkansas)...lol
click the pics to see them full size
Last edited by sparkys-crewcab on Wed Jan 12, 2011 5:33 pm, edited 4 times in total.
AlbertaAMX
New postPosted: Wed Oct 20, 2010 8:40 pm
610
Does that build sheet show a gross combined weight rating? Build sheet doesn't blow up for me.
sparkys-crewcab
New postPosted: Wed Oct 20, 2010 9:28 pm
5350
i fixed the pic..
edit.. the shipping weight of the truck is 3193 pounds..
the gross vehicle weight rating is 10,000 pounds.
sparkys-crewcab
New postPosted: Thu Oct 28, 2010 9:05 pm
5350
today i got off my lazy ass and cut the transmission/driveshaft hump out. the sawsall did the job very quickly.
i stuffed the engine/trans back it ..
the carb/air cleaner should fit under the stock hood with no problems. the distributor cap may hit the firewall. its going to be close if it doesn't hit..
fits like a glove...
No new posts My New SquareBody
971
Mon Sep 05, 2011 10:05 pm
New posts View first unread post Attachment(s) 77 CC squarebody sfbd build thread..almost a roller.
[ Go to pageGo to page: 1 ... 23, 24, 25 ]
sparkys-crewcab
361
22937
Sat Feb 11, 2012 2:05 pm
watahyahknow View the latest post
Users browsing this forum: DZL1, green monster, TakinItBack and 6 guests
