Post new thread Reply to topic  [ 190 posts ]  Go to page Previous  1 ... 3, 4, 5, 6, 7, 8, 9 ... 13  Next
joebob
 Post subject: Re: My crew cab '86 square
New postPosted: Sat Mar 13, 2010 5:24 pm
160
hey do you have a part number on those headers because i can only find raw or ceramic ones and i want painted ones...thanks
New postPosted: Sat Mar 13, 2010 7:02 pm
1986 Chevrolet Crew Cab Dually
4830
They are the raw Patriot Clipster headers for a '69 Chevelle that Summit sells. I rattle canned them before taking the pics. I used regular paint instead of high temp. paint and now they are raw again. Either way the finish would have been ruined because they had to be slightly modded to fit right. The right side was rubbing on the frame and the left side was rubbing on the motor mount and hitting the oil filter on my factory oil cooler equipped truck. But, they were well worth it, the truck has a DEEP low end sound.
'86 Crew Cab-Cam+Bolt-ons BBC,TH400 G/V O/D Equipped, Built C&C, 6/10 on 24's
davidgonzales
New postPosted: Sun Mar 21, 2010 11:18 pm
480
hey that truck kicks ass i hope mine can get to that point soon.
New postPosted: Sat Jun 19, 2010 1:23 pm
4830
Well I haven't gotten much progress on the dually because of work but, now I am only working 5 days a week so i will have a lot more time now compared to before..
I finally got the billet pedals installed that I have had laying around since last year-
I finally installed my new lockable K5 Blazer center console, I had to fab up some cutom mounts and use some parts from the old woodgrain center console-
The truck is going to be my 4 door, 6 wheeled sport truck so I had a custom badge made for it at work and installed it on the console-
I purchased a Gear Vendors Overdrive Unit and did a "stealth" install of all the electronics inside of the new console-
New postPosted: Sat Jun 19, 2010 1:31 pm
4830
I do however have a lot of new parts which I want to have installed very soon.
Gear Vendors Overdive for my Turbo 400-
Edelbrock Performer RPM Air Gap intake manifold which I cleaned up the ports on in the same way I did the headers-
Bigger pushrods-
72gph electric fuel pump, Comp roller tip rockers, and cam and lifter kit reccomended to me by Comp Cams for my application-
"781 Oval ports "assembled with stiffer springs," stud guides, gasket matched with some "nice" portwork, and "bigger stainless valves." These came off of a '70 chevelle drag car and they are "ready to go." The guy replaced them with some Dart aluminum heads and said my 781's "weigh a lot more but, damn near flow as much as the Darts."-
I think the truck is really going to wake up with the new parts and no loss of fuel mileage because of the overdrive.
Last edited by WIDE LOAD C-30 on Sun Aug 01, 2010 3:21 pm, edited 1 time in total.
New postPosted: Sat Jun 19, 2010 1:48 pm
4830
When I ordered all the billet stuff for the interior I accidentally ordered 2 sets of front door trim pieces instead of 1 front set and 1 shorter rear set. I didn't want to go through the hassle of shipping them back to LMC and losing money on shipping etc, so I cut them to length, contoured them and used the leftover pieces aswell-
I ordered another set of '79 front end style clear sidemarkers from LMC and installed them on the rear of the rear fenders with the reflector on the bottom and red LED bulbs since these lights are supposed to be red. They are very bright and I will post night time pics later-
This is what the LMC water proof cover for a crew cab long bed fits like on a dually-
I had to mark an X on the front because it is so long and I also cut some slits in the bed area because it would turn into a pool after it rained.
About a month and a half ago I hit a BIG pothole at the front right and the wheel traveled so far it broke the stock A/C box into pieces, it even pushed the blower motor up causing the blower fan to break when it hit the firewall. I bought another stock A/C box and blower fan and modded it with a freind that works at a body shop. The blower motor was cut and raised up much as possible without the fan rubbing on anything and the A/C box was cut as much as possible on the area close to the tire and fiberglassed. It gained about another 2 inches of clearance- :quagmire:
New postPosted: Sat Jun 19, 2010 9:20 pm
4830
Here are the other pictures I said I would post-
LED tails and LED rear fender lights-
LED tails with brake lights on-
Front, rear fender lights-
Front lights-
Front lights with high beams on-
HID's are on the to-do list.
New postPosted: Sat Jun 19, 2010 9:21 pm
4830
The paint/bodywork are going to be some of my last mods but I already have all the parts for that aswell:
New cab corners and clear LED roof lights for the cab-
New smooth tailgate-Image
ALL new weatherstrippings, door seals, and misc nuts and bolts for the cab-
Tailgate handle relocation kit and K5 Blazer tailgate band that I have alredy modded to fit on the truck tailgate so I can have a shaved handle with no metal work-
Polished trim for the stock grille that I had to make cut outs for the bowtie in order to work on my grille. And some later model square body 'burban mirrors. These mirrors were only made 1 or 2 years and there is not enough demand for them, nobody makes them. It took me a long time to find a decent pair.-
It also took me a long time to find this metal piece that fills in the gap in between the bumper and the bed, it came on K5 Blazers and some 'burbans. :
I've also done other small things that probably nobody notices except me like have the key holes shaved and add some "bling" under the hood.
New postPosted: Sun Jun 20, 2010 7:25 am
49450
got alot of new goodies
New postPosted: Sun Jun 20, 2010 9:21 pm
4830
Next time I post pics it will be of goodies on the truck. I just dropped it off today for the O/D, and heads+cam install, etc.
sparkys-crewcab
New postPosted: Sat Jul 31, 2010 3:00 am
1977 GMC sierra 3500
5350
one of these days my truck is going to look this good...
any plans to body drop it?
LUV2XCLR8
New postPosted: Sat Jul 31, 2010 6:20 am
2000 GMC Crew Cab
6290
Looking good man!
PROJECT: "SQ VET" 72 BLAZER 2WD
TOW RIG: "GAS HOG" Y2K GMC 3500
Owner/Admin "TN Classic Truck Club"
................... _______
......._________|___|___\_____
......|__((O))__|___|___|_(O)_|
New postPosted: Sat Jul 31, 2010 6:55 am
4830
Thanks guys. And no I don't have any plans to body drop it but it's notched and tubbed to layout in case I decide to bag it later. I would however like to run a vintage air setup so I can static drop the front another inch on bigger tires.
yellowGT
New postPosted: Sat Aug 14, 2010 11:55 am
390
wide load...did you literally turn and flip the rearend? looking at your pics it looks like you did without a flip kit. Everything looks the same just upside down is this correct?
New postPosted: Sat Aug 14, 2010 2:40 pm
4830
LOL, hell no. I'm running a rebuilt '85 model C&C rear which is a FF 14 bolt. It does look upside down compared to the stock rear when looking at the diff. cover.... The Western Chassis flip kit does not work with this C&C, so a custom one was made.
No new posts 89' chevy crew cab dually project. take a look-
04_duramax
424
Tue Jan 31, 2012 4:28 pm
STROKED View the latest post
No new posts Attachment(s) 94/69 Retro Crew Cab Dually
Possmguts
14
782
Wed Feb 01, 2012 9:53 pm
Possmguts View the latest post
No new posts Crew cab, cab corners
igorsgonemadd
232
Mon Dec 19, 2011 9:52 pm
drps10 View the latest post
No new posts hey guys big question ??? suburban to crew cab conversion ??
BowtieBoy69
264
Mon Oct 31, 2011 1:14 am
circuitguy View the latest post
No new posts stock flooring my crew cab an looking for some input please
TJIV80
18
1179
Thu Dec 08, 2011 9:43 pm
WIDE LOAD C-30 View the latest post
No new posts Stockfloorin my 2000 crew cab on 22's..
[ Go to pageGo to page: 1 ... 9, 10, 11 ]
LAYINGNUTZ
150
11285
Tue Feb 07, 2012 10:49 am
Jeebus View the latest post
No new posts Just Curious Has anyone Built UP a old 73-87 Crew Cab Dually
CowboyProtectionUnit
855
Mon May 09, 2011 4:07 pm
CowboyProtectionUnit View the latest post
No new posts Attachment(s) IIGW.org 83 Crew Cab
[ Go to pageGo to page: 1 ... 5, 6, 7 ]
bk2life
98
6610
Tue Feb 07, 2012 1:25 pm
bk2life View the latest post
No new posts 1985 Chevy 1 ton Crew Cab - Cummins Swap
Cubicdollars
24
5083
Wed Jan 11, 2012 8:59 am
Cubicdollars View the latest post
No new posts 88 Crew Cab Project Plain Jane
dentman
20
1663
Sun Mar 20, 2011 10:57 am
Users browsing this forum: leedogg and 3 guests
