Post new thread Reply to topic  [ 39 posts ]  Go to page 1, 2, 3  Next
Guilty By Design
 Post subject: New Bracketry
PostPosted: Mon Jul 12, 2010 11:06 pm
14560
Just got alot of new items cut today.
3'' Nissan gusset
3'' Ford gusset
New frame tabs
And heres an item im rather proud of. This baby welds to a crossmember you have on the ground and locates all 4 front 4 link mounts. The beauty behind this bracket is its designed to work with my axle tabs to space all the pivot points equally and its modular insert adds considerable strength to the top mounting locations. Simply tack weld the inserts countersunk legs into the tab holes and grind smooth for a seamless look. That keeps your 4 link working properly and saves you time setting everything up. The bracket keeps the bottom bushing 1/4'' off the ground, feature a flatspot 1/4'' from the edge of the tubing so you can wrap your weld around the end. Its made of 1/4'' pickled&oiled steel. P&O steel makes for a cleaner cut edge and has virtually no millscale cutting down on your metal prep time. It also features a full shoulder surrounding the polyurethane bushing just ike all my tabs. Other tabs dont cover the entire bushing and that could lead to the tab cutting into the bushing or causing premature wear. Hell it just looks better too!
All that and theyre STILL cheaper than similar bracketry found on other sites.
Guilty By Design
 Post subject: Re: New Bracketry
PostPosted: Tue Jul 13, 2010 8:54 pm
14560
Showin some dually love with these
Stop spending all day on the bandsaw, these 4'' upper and lower axle tabs just for you!
I also got my diamond shear load plates in today
Guilty By Design
PostPosted: Wed Jul 28, 2010 2:49 pm
14560
A couple of new items today!
First is an 8pc mazda specific notch kit. These notches mate up to the mazda framerails perfectly and allow you to lay frame on a 255/35/20.
Second is a universal 8pc octagnal notch kit. For those of you who want a little more shape than the boring standard notch kits.
Both are lazer cut from 3/16'' P&O mild steel and are in stock now. Ill have them available at my booth this weekend at Slamily Reunion.
http://guiltybydesign.net/?category=Bra ... ry=Notches
Guilty By Design
PostPosted: Sun Aug 08, 2010 1:56 pm
14560
I just got my keychains in!
http://guiltybydesign.net/?category=Swag
Guilty By Design
PostPosted: Wed Sep 01, 2010 12:20 pm
14560
3 new gussets today.
http://guiltybydesign.net/?category=Bracketry&subcategory=Gussets
I also got these bad boys in
Guilty By Design
PostPosted: Mon Sep 13, 2010 5:40 pm
14560
Customers gussets
Had to run nitrogen through the lazer to keep it cool enough to get this intricate but we got it done.
New axle mount.
With this you can mount your upper 4-link bars to the lower bag bracket. Simply weld the top 4 countersunk tabs to the bag plate and grind smooth. Works with 2500 or 2600 lb bags and available for 2.75'' and 3'' axles.
PostPosted: Tue Sep 14, 2010 9:24 am
49270
Looks good Kyle. Our painter here in the shop want to know if you can do the No Regrets logo in a gusset.
Guilty By Design
PostPosted: Tue Sep 14, 2010 12:28 pm
14560
Yep, even already have the NR logo drawn already. Have him email me kyle@guiltybydesign.net
PostPosted: Tue Sep 14, 2010 3:13 pm
49270
Will do it.
Guilty By Design
PostPosted: Wed Oct 27, 2010 8:16 pm
14560
New gussets and frame tabs.
bigperm
PostPosted: Wed Oct 27, 2010 10:53 pm
770
your parts look super good!
curious.. what would a pair of lower balljoint cups for a 98 chevy 1-ton run me?
Guilty By Design
PostPosted: Fri Oct 29, 2010 6:34 pm
14560
I dont do machining, hit up Taylor at Michigan Metal Works. Tell him i sent you.
Guilty By Design
PostPosted: Mon Nov 22, 2010 7:12 pm
14560
This side filler panel makes skinning your trailer fenders a breeze.
*Lazer cut from 16ga mild steel.
*Fits standard 9''x 32'' single wheel fenders.
*Sold Individualy
http://guiltybydesign.net/?category=She ... ry=Fenders
LUV2XCLR8
PostPosted: Tue Nov 23, 2010 9:12 am
2000 GMC Crew Cab
6450
That is a cool piece, now I just need the
trailer fenders, lol. (Thinking of doing my
72 w/ this set-up cause inners won't fit)
PROJECT: "SQ VET" 72 BLAZER 2WD
TOW RIG: "GAS HOG" Y2K GMC 3500
Owner/Admin "TN Classic Truck Club"
................... _______
......._________|___|___\_____
......|__((O))__|___|___|_(O)_|
Guilty By Design
PostPosted: Wed Dec 15, 2010 9:56 pm
14560
98+ 2WD Ford Ranger Tranny Crossmembers are in. These are lazer cut out of 1/4'' P&O steel and .125'' wall tubing. They use all 3 stock mounting holes and clear the ground without dragging or high centering the truck.
$149.99
http://guiltybydesign.net/?category=Crossmembers
New posts View first unread post New Bracketry
[ Go to pageGo to page: 1, 2, 3 ]
Guilty By Design
38
1727
Mon May 21, 2012 7:04 pm
loweredd View the latest post
