Post new thread Reply to topic  [ 13 posts ]
 Post subject: feasability study
New postPosted: Tue Dec 19, 2006 3:23 pm
I found a 2 speed rear end in the local junkyard. They claim it came from a bus? It already has a 10 bolt wheel pattern. It measures about 70" from ms to ms. Which would be about 3" narrorer than my stock rear. The pumpkin measures 21" :shock: and the rotors on the stock disk brakes measure a shade over 16". Does anyone have any idea how I could find the gear ratios? Could I run that with an auto tranny or would it have to be manual? Are all 10 bolts the same pattern? Can you get 10 bolt 19's since 22's wont fit on a doored square body? And heres the big one, is there any chance I could make it fit?
I'm sure I'll think of more ?'s but I thought it would be pretty cool to have a 2 speed rear and something that beefy. Gonna take 1 hell of a notch.
Also is there a market for my stock rear 4:10 w/ posi?
HANGSLO
New postPosted: Tue Dec 19, 2006 4:25 pm
990
The only sure fire way to find out the ratio(s) would be to count the teeth. As for the tranny, you could run whatever tranny you want as long as it is strong enough and the gear ratios will work for you.
You can get 10 bolt 19.5's if you look around for them, and 22's will fit on a doored square body, cause my friend has one.
anything that goes really fast and gets really shitty gas mileage has got to be cool ...
New postPosted: Tue Dec 19, 2006 4:27 pm
You can't get a very low profile 19.5 tire. I was going to try and get a 22 under there but it seems to be general concensus that it wont fit. I don't really feal like pulling the carrier to count the teeth, but I may have to. I thought if I could get it to spin I could count that way.
New postPosted: Tue Dec 19, 2006 5:49 pm
67840
Not real sure if an auto trans would work right with a two speed rear.
It's been MY experience that typically when going into high from low (or vice versa) you need to be able to match the RPM's of the motor/trans, to the speed of the rear end. Not to easy to do with an auto trans.
Not saying its IMPOSSIBLE, just maybe not too practical.
We had an old '86 Ford L-8000 dump truck with a 5/2. Those 2 speed rears will grind a bit, but once you get the hang of it, there quite handy. I would typically leave it in low around town and only kick it up into high when I was on the freeway or running empty.
New postPosted: Tue Dec 19, 2006 5:54 pm
I can buy the axle for $150 so I might not be out much to try it. I dunno. Can you shift them not moving?
New postPosted: Tue Dec 19, 2006 6:06 pm
67840
Uh...
I think so, yeah.
New postPosted: Wed Dec 20, 2006 9:49 am
It came out of either a 70 or 75 chevy school bus.
New postPosted: Wed Dec 20, 2006 11:52 am
So is trying to use a 2 speed bus axle in my dually a dumb idea??
New postPosted: Wed Dec 20, 2006 12:07 pm
67840
Eh.
It's a tad bit overkill if you axe me.
New postPosted: Wed Dec 20, 2006 12:14 pm
My hope was that the high gear would be like a 3.08 or something like that. Then I could really go on the hiway.
New postPosted: Wed Dec 20, 2006 1:17 pm
67840
No.
It's nothing like that. At best, your "high" would be like a stock gear ratio (4:11?), but the "low" would be REALLY low. Even in "high" and 5th, our old dump would be screaming going down the highway at 65.
Like I said, there great for pulling Bobcats or school kids, but I think you will find it's way overkill and a little more trouble than what it's worth.
But it would be heavy duty, thats for sure.
New postPosted: Wed Dec 20, 2006 1:22 pm
It was one of those things where I was walking the junkyard and seen it sitting there and it got the old wheels a turnin in the head. yunno what I mean.
New postPosted: Wed Dec 20, 2006 1:40 pm
67840
Abort.
New posts View first unread post feasability study
1569
Users browsing this forum: No registered users and 16 guests
cron
