Post new thread Reply to topic  [ 22 posts ]  Go to page 1, 2  Next
bigo181979
 Post subject: Bagging with Semi's and Stock Fenders, got a couple???
PostPosted: Mon Jan 03, 2011 4:06 pm
1992 Chevrolet Crew Cab Dually
780
So I am sure this has been asked before so if so plesae just point me in the direction...
So when I get to the next step in my truck build I want to bag it with some 22" semi's but I want to run stock dually tubs since my flames go over the tubs and I don't want to try and match candy paint...
So what do I need to do and what kind of link set up can I run on the rear and what about wheels? Do I need to narrow my axle? Also I do NOT want to relocate the tank.... Also i still use this to tow a big ass boat too...
Please help point me in the right direction.... :quagmire:
LUV2XCLR8
 Post subject: Re: Bagging with Semi's and Stock Fenders, got a couple???
PostPosted: Mon Jan 03, 2011 4:49 pm
2000 GMC Crew Cab
6450
I'm sure Trevor @ TWAT will chime in eventually
because he knows this stuff inside & out. I think
the only way u can keep the stock rear fenders is
"Townasty's" (I think that's what they are called)
But if you just want 22 outers in the rear I think
it's a non issue as far as widening your fenders.
PROJECT: "SQ VET" 72 BLAZER 2WD
TOW RIG: "GAS HOG" Y2K GMC 3500
Owner/Admin "TN Classic Truck Club"
................... _______
......._________|___|___\_____
......|__((O))__|___|___|_(O)_|
bigo181979
PostPosted: Mon Jan 03, 2011 5:59 pm
780
Honestly I wanted to run 6 semi's.....
LUV2XCLR8
PostPosted: Mon Jan 03, 2011 6:32 pm
2000 GMC Crew Cab
6450
I think the only way is the "Townasty's"
or widen the inside / shorten rear end.
bigo181979
PostPosted: Tue Jan 04, 2011 9:58 am
780
Yeah I am cool with going inward, no big deal on cutting up the inner fender or bed, just don't want to touch the outside...
Then I need to see what kind of link set up I can run... I don't want to relocate the tank...
Hopefully someone knows for sure and will chime in.
PostPosted: Tue Jan 04, 2011 10:40 am
49270
What year is your truck? I see a 92 model in your garage so I will answer as if we are talking about that truck.
Your best bet is going to be to narrowing the rear axle to run 6 wheels on this 92.
When you narrow the axle you are going to have to make some changes to the rear frame on the truck. I would build a new back half if it were mine that way you can keep the tank in the same spot and build all of your hangers to accommodate your link system. The room you have around the tank, frame, and axle on the drivers side is going to determine the link setup that will be the best for you. From what I can remember there is not alot of room there when you narrow the axle, so if you build a new back frame section you may be able to mount a link bar on the outside of the tank and still get clearance for the bar to mount to the axle without hitting the wheel/tires.
bigo181979
PostPosted: Wed Jan 05, 2011 9:27 pm
780
Yes this is on the 92, so what if I don't want to back half it... what if I just wanted to notch it? would a teen and a 22 fit if I narrowed the axle?
PostPosted: Thu Jan 06, 2011 10:08 am
49270
Just going to be one of those things you are going to have to measure to see what clearances you are going to have. With you not wanting to move the tank you are cutting your link option room down also.
bigo181979
PostPosted: Thu Jan 06, 2011 10:58 am
780
Ok good to know. Well if moving the tank is necessary what are my options? I do not want to have the tank sitting in the bed. Does anyone make a tank to go under the bed or what are other people doing?
LOWBOY MSPORTS
PostPosted: Thu Jan 06, 2011 1:18 pm
260
Moveing the tank isnt required. Narrowed or c&c axle. Run a 16 on the inside. Move your lower link bars below the frame, upper link bars between the frame.
Lowboy Motorsports
240 E Coury Ste 101
Mesa, Az 85210
WWW. LOWBOYMOTORSPORTS.COM
PostPosted: Thu Jan 06, 2011 5:28 pm
49270
No tank moving if you run a 16" inner (like Lowboys Pics above). If you want to run the inner 22s you will have frame clearance issues, therefore the tank will need to go somewhere. You may could plate and pocket the frame rails to step them inwards toward the center and get the clearance you would need.
LOWBOY MSPORTS
PostPosted: Thu Jan 06, 2011 5:52 pm
260
Another option you've got, just came to me, is to go to a short bed tank, which is a good 12 inches shorter plus. That'll give you enough room to build a new rear frame clip narrow.. enough to run inner 22s as well.
Lowboy Motorsports
240 E Coury Ste 101
Mesa, Az 85210
LUV2XCLR8
PostPosted: Thu Jan 06, 2011 5:59 pm
2000 GMC Crew Cab
6450
LB, That truck pictured is it yours or one
you did? How much louder was Exhaust?
LOWBOY MSPORTS
PostPosted: Thu Jan 06, 2011 6:39 pm
260
Customers. He took and had the exhaust done after. He wanted it quiet
Lowboy Motorsports
240 E Coury Ste 101
Mesa, Az 85210
bigo181979
PostPosted: Fri Jan 07, 2011 10:10 am
780
Dude thats exactly what I am looking for!!!! Thats how I want mine to sit, guess I am going to have to run a teen on the inside.
Is that thing set up like with a 6 link? Maybe its the pictures but it looks to me like there are 2 link bars running from the back side of the axle to the back of the truck with the bags mounted to them... Am I seeing that right?
What size tires are people running/how tall???
No new posts Bagging with Semi's and Stock Fenders, got a couple???
bigo181979
21
1393
Fri Jan 28, 2011 10:27 am
lockone View the latest post
No new posts bagging a dually
custom86dually
23
1094
Sun Aug 17, 2008 2:55 pm
gkrew View the latest post
No new posts Bagging questions
881ton
10
1253
Fri Jul 07, 2006 9:22 pm
Users browsing this forum: No registered users and 17 guests
