Post new thread Reply to topic  [ 16 posts ]  Go to page 1, 2  Next
 Post subject: Trouble starting.....?
PostPosted: Sat Jun 23, 2007 6:12 pm
1999 Chevrolet crew cab
11840
Maybe you guys can tell me whats the problem. Occasionally, mainly when it is hot out it seems......I go to start my dually and it keeps turning over and after a couple tries it finally fires. I put new plugs and wires on last week and it still does it. It doesnt do it all the time just everyonce in a while. When I drive it, it acts fine....no problems at all. Only when its been sitting in my driveway for a while and I go to start it does it give me problems. I am going tommorrow to get a new fuel filter for it.
PostPosted: Sat Jun 23, 2007 6:29 pm
11840
And wtf is this .......
...apparently the guy that owned it before me broke the fitting off the top of it, and decided to use glue or RTV or something to hold it together....well it didnt work to well and it looks like crap. I would look into a new one if I new what the hell it even is.
PostPosted: Sat Jun 23, 2007 7:13 pm
72500
possibley your fuel pump?
PostPosted: Sat Jun 23, 2007 7:25 pm
11840
PostPosted: Sat Jun 23, 2007 7:27 pm
72500
charcoal canister maybe?
PostPosted: Sun Jun 24, 2007 1:27 am
hell whats the white stuff all over the valve covers
you sicko
PostPosted: Sun Jun 24, 2007 5:42 am
maybe its vapor lock the gas inside the line is turning to gas making bubbles in the line gasing the engine to momentairily run too lean , a quick fix (when running in the mountans ) is too cool the line with water or ice .
a more permanent solution would be to route the line away from heatsources like exaust get more air under the hood and isolating the line
PostPosted: Thu Sep 06, 2007 3:46 pm
11840
Well I took it to a mechanic that is next door to Jakes shop thats bagging my truck. He said it was the starter getting hot and causing my trouble w/ starting.........I was like cool, put a new starter on it while its already next door at Jakes. Put starter in last friday and it sat in the guys shop all weekend while Jake went to RA Allstar show. Jake went to move it to his shop tuesday and now the volt meter on the dash is reading like 10 volts....was reading just fine when Jake had the truck before the new starter. Mechanic says I must have an alternator going bad or is bad and tell Jake he will gladly put a new one in for me.( I am sure he would.... :evil: ) I am starting to maybe smell a crook here...? Never heard of a new starter causing your truck to have a problem charging, have any of you? What do some of you think...seeing as you are fellow dually owners...I like to here your opinion on the matter.
PostPosted: Thu Sep 06, 2007 3:56 pm
I would check some of the connections. I don't know how those new fangled trucks are but the older ones all the voltage runs through the starter connection, so maybe something is loose or not hooked up right.
Or maybe you have bad luck, and your alternator and starter went out about the same time. That sounds like something that would happen to me.
Or maybe he is a crook.
PostPosted: Thu Sep 06, 2007 5:18 pm
49260
Voltage regulator????
PostPosted: Thu Sep 06, 2007 5:51 pm
11840
What the hell is that..? Is that like a Flux Capacitor..? That sounds expensive.
PostPosted: Fri Sep 07, 2007 1:44 am
yea its new they started to put them in the alt. when they quit using generators :lol:
pull your alt. and have it tested
diabolic kustoms
PostPosted: Fri Sep 07, 2007 7:58 am
1983 Ford Ranger
11820
with your truck running hold a screwdriver to the back of the alt. if it is magnatized it is working if not, get a new alt.
souless and lovin it
PostPosted: Fri Sep 07, 2007 8:09 am
11840
Went and bought a new alternator last night...100$ brand new w/ lifetime warranty.So new plugs, plug wires, starter, alternator, and called about a regulator and said they would have me one at the shop by 9:30am for 30$. I think the only damn thing left to replace on the truck is the A/C compressor, and it quit kicking on just before I dropped it off to get bagged :( So I will probably be buying one of those when I get the truck back it looks like.
PostPosted: Fri Sep 07, 2007 8:11 am
11840
Makes me so damn frustrated when shit breaks on my rides......but I guess I should be lucky , since the truck is paid off. I could be making a car payment every month and fixing shit going wrong .
No new posts HELP!!! troubleshooting
svrdwgn
453
Wed Apr 21, 2010 8:33 pm
svrdwgn View the latest post
No new posts transmission troubles.
poopskidz
210
Fri Sep 11, 2009 9:58 pm
poopskidz View the latest post
No new posts having trouble starting after it sits
abescustoms
325
Sat May 24, 2008 11:19 pm
abescustoms View the latest post
No new posts Trouble starting.....?
15
1076
Fri Sep 07, 2007 8:18 am
