Post new thread Reply to topic  [ 17 posts ]  Go to page 1, 2  Next
allstar59
 Post subject: tbi changing to carb??
PostPosted: Mon Feb 02, 2009 8:25 pm
1988 Chevrolet crew cab dually
320
Has anyone ever done this swap. I am rebuilding my motor and was thinking about changing to a carb. I have a 88 crewcab sqbdy with a 454. Has anyone done this swap and if so what does it entitle me to do. Any help would be great. Thanks Guys.
 Post subject: Re: tbi changing to carb??
PostPosted: Mon Feb 02, 2009 9:08 pm
49840
ok well im doing the oppisite swap on mine... i have a 80 and im puttin tbi from my 88 on it.... to switch to carb you are gunna need the new intake, new distrubuter and you can loose the O2 sensors in the exhaust manifold. thats all you will need to do the swap.
PostPosted: Mon Feb 02, 2009 9:36 pm
13180
If you're going to use the TBI pump in the tank, you're going to need a bypass style fuel pressure regulator. Aeromotive makes a nice one, the only one they have with hose barb fittings instead of AN, for about $100 from Jeg's. If you use a regular dead-end style cheapie regulator it'll be hard to set the pressure correctly and eventually you'll kill the pump dead-ending it like that. The bypass style regulator has a return line to the tank like the old TBI setup used. That TBI pump can put out up to 14 psi (up to 32 psi on the '94 model 454 TBI) and your carb wants about 6 psi.
PostPosted: Mon Feb 02, 2009 10:11 pm
and if your doing away with all of that your computer wont shift the trans right and the lock up converter wont work thats if you have the el 3spd with overdrive automatic
hey someotherguy I've been doing some reserch on gm style electric pumps and the majority of the TBI pumps run between 12 psi and 30 psi and 19gph to 27 gph but... the pump that goes in a 96 c3500 has a psi of 34 and runs at 43.5 gph so if you running an ajustable regulater on your TBI you can really crank up the pressure and hold it there at wide open. I just changed my pumps out on mine and it woke my motor up
the pump part # is acdelco ep381 and I crossed that over to the delphi witch has a little higher numbers
PostPosted: Mon Feb 02, 2009 10:27 pm
Pig anything over about 13 psi is just going to try and push open your needle and possible flood the carb. The higher volume may help but higher pressure after a certain point will probably cause more problems.
PostPosted: Mon Feb 02, 2009 10:50 pm
13180
Pig, a '96 will be Vortec, which will be around 50-something psi for a big block, closer to 60 for a small block. If you're playing with an adjustable FPR on a TBI and want more than the 14 psi or so that most of the TBI pumps give, get a pump for a '94 454. The '94 454 is still a TBI, but while the earlier 454 TBI's ran the same 9 to 13 psi spec that a small block TBI runs, the '94 has redesigned injectors and run at a higher pressure. The test spec on a '94 454 TBI is 26 to 32 psi.
allstar59
PostPosted: Tue Feb 03, 2009 12:22 am
320
I have a turbo 400 trans. so will this still wwork or am I dreaming. And if I'm dreaming then could you tell me what to do to make my tbi better.
PostPosted: Tue Feb 03, 2009 12:57 am
the th 400 will work with out the ecm
a tbi motor is a fairly easy motor to get power out of because their detuned from the factory
bump up your fuel pressure with a adjustable regulator
a good set of plug wires, high out put coil and a msd 6al spark multiplyer helps and you can also open the gap up on your plugs also
make that f^ger choke on as much cold air that you can physicly force down the throttle body
last but not least have some one that IS GOOD reprogram the ecm
heres some sites
a good place to get tbi parts
http://www.rvmorsemachine.com/index.html
http://www.tbichips.com/
here's alot of good reading on getting power out of these motors
http://www.454ss.com/index.asp
heres the guy that I'm going to have reprogram my ecm when I get my truck running agine look at some of the number gains
http://www.trifectaperformance.com/default.aspx
PostPosted: Tue Feb 03, 2009 1:20 am
I'm only running 12psi but thats from idle to wot as were my stock pump I couldnt get more then 10psi and it would drop down to 1 or 2 psi at wot
my understanding is the psi rating is based on the initial hit so you want to look at the gpm also for the amount of fuel it will get
the gm pumps are all the same when you look at them there might be some differances here and there but their all interchangable their differance is how much fuel they push
I don't want to start a pissing match but I know that with the new pumps in my truck its a lot more responsive and its alot crisper sounding and I have a lot better mid range power band now
PostPosted: Tue Feb 03, 2009 6:37 am
I thought maybe you were trying to push like 20psi. I've seen guys try it.
PostPosted: Tue Feb 03, 2009 10:43 am
13180
Yes and no, that '94 454 TBI pump is higher pressure (which as you already know pressure and volume are different), and '96 Vortec is a big jump in pressure. Once you get around mid-'97 then they screwed everyone with that integrated pump and sender assembly in the big plastic can that costs $300 if you buy a good one.
No pissin' match at all bud. I think your old pump was just going bad. 10 psi running and dropping to near nothing at WOT tells me it was on its last legs.
PostPosted: Wed Feb 04, 2009 12:00 am
yea my pumps went tits up and part of the reson for going with lots more presure was my engine is a long ways from being stock and I'm toying with the idea of making some more changes for the better :twisted:
allstar59
PostPosted: Wed Feb 04, 2009 12:09 am
320
So i am looking to run a Holley truck avenger 770 cfm carb with a Elderbrock Proformer idle-5500 rpm
Ignition is going to be a Msd RTR distributor, a Msd 6AL box, and a blaster # coil, with Msd wires.
Does that sound like it will take care of the change over from TBI to carb. Please let me know if this looks right and/or if I am missing anything? Thanks Guys.
PostPosted: Wed Feb 04, 2009 12:34 am
But yet you post no pictures and have no buildup thread.
Jeffrodamis
PostPosted: Wed Feb 04, 2009 4:54 pm
1993 Chevrolet Crew Cab Dually
2960
piggybackin on this thread..i got a 305 with vortec heads for 100 bucks...i need a intake manifold for it for a carb...any help? all i found was edelbrock and professional products..any personal experience? thanks duders
"i aint no venereal fuddrucka"
No new posts 1994 TBI 7.4l TPS problems
biskit
486
Fri Mar 11, 2011 11:59 pm
No new posts 95 TBI no crank issue
Klez
184
Wed Mar 03, 2010 3:20 pm
Klez View the latest post
No new posts 88 TBI runnin like crap!
OneFastHoagie
18
652
Sun May 10, 2009 10:12 pm
No new posts tbi changing to carb??
allstar59
16
493
Thu Feb 05, 2009 12:25 am
No new posts Starting Issue, '87 TBI 350
kdubaz
748
Mon Jun 04, 2007 9:59 am
Users browsing this forum: No registered users and 5 guests
