Post new thread Reply to topic  [ 14 posts ]
 Post subject: Starter Woes...
New postPosted: Thu Aug 06, 2009 11:24 am
67780
Here’s the issue:
I go to start the truck a few weeks back and it turned over and started fine, but when I let go of the key, it kept turning over. It only did it for a few seconds.
Flash forward to last week. Went to start the truck and the same scenario happened only this time, the starter wouldn’t stop turning. I even pulled the key out of the ignition. The only way to get it to stop was to disconnect the battery.
Figured the contacts in the starter arc’d due to a low battery or something of the like. I replaced the starter and the battery, went to fire it up, and the same thing happened. Brand new starter kept turning over even after the engine fired.
I have an idea what the problem is, but I wanted to throw it out there to see if anyone else has had any experience with this sort of thing.
erock805
 Post subject: Re: Starter Woes...
New postPosted: Thu Aug 06, 2009 1:51 pm
1994 Chevrolet Crew Cab Dually
5340
Ignition switch or the starter is hangin up. shim it.
http://www.myrideisme.com/Garage/erock805
54 chevy
64 C10
61 ford Econoline
70 Electra Glide
04 Road King
"Ya know Peppa, you cant polish a turd!"
1967rs
New postPosted: Thu Aug 06, 2009 10:37 pm
590
2X Ignition switch at the bottom of the colum
New postPosted: Fri Aug 07, 2009 9:33 am
67780
Roger that.
That's what I thought.
New postPosted: Mon Aug 10, 2009 11:09 am
67780
Negatory...switch and actuator rod are A-okay.
Only link left is the wiring between the switch and the starter…guess I'll have a looksie tonight. Maybe I have sumthin' touchin'.
New postPosted: Mon Aug 17, 2009 12:57 pm
67780
Wires look good...still have the same issue. Shimmed the starter...no dice. Anybody have a wiring diagram for the starting system? This is really getting to me.
One other note of interest...the 'start' lead is constantly hot. I've already replaced the ignition switch. Is there a relay that I'm missing.
I've also been told to see if the neutral safety switch is going to ground.
If anyone has any insight, I'd appreciate it. I'm about to set this sucker ablaze.
New postPosted: Mon Aug 17, 2009 3:01 pm
1982 GMC classic
5420
here the dig i have
http://vintage.mitchell1.com/base/pdfviewer.asp
http://vintage.mitchell1.com/PClubdata/ ... ssis_Truck
New postPosted: Mon Aug 17, 2009 3:11 pm
67780
I need a password, Sucka!
New postPosted: Mon Aug 17, 2009 4:52 pm
sorry I couldn't help you more saturday when you called but I had a lot going on at that moment :lol:
so you've chased wires pull you fuse block apart theres a bolt in the center of it on the engine side open it up and see if something is arcing also pull the junction block loose from the fire wall so its not touching and see if that makes any differance
you might just need to check every conection point
just something to think about once I had a tail light problem that I chased for weeks It would burn out bulbs or fry fuses some time both and some times I'd lose all my lights I finaly traced it to the fuse block the terminal had broke loose and it would touch other terminals
good luck and happy hunting
New postPosted: Mon Aug 17, 2009 6:46 pm
1982 GMC classic
5420
i tryed to call ya but u dont anser your phone cuz your afrad to talk to me cuz u have not got me thous wires
erk
on the side of the road out of gas
New postPosted: Mon Aug 17, 2009 9:13 pm
ARE YOU TRY'N TO CALL ME
New postPosted: Tue Aug 18, 2009 9:14 am
67780
That's not true...:lol:
New postPosted: Tue Aug 18, 2009 10:36 am
1982 GMC classic
5420
na i waset trying to call ya pig was trying to call campys ass so i could give him the password
erik
still on the side of the road out of gas waiting for my wires from campy
New postPosted: Mon Aug 24, 2009 11:29 am
67780
Replaced the neutral safety switch. Seemed to fix it...kinda.
It did it to me once again after I replaced the switch, but it's been fine since then. I don't quite trust it. I still have a 5/16" nut driver on my dash in case I need to disconnect the battery. :lol:
No new posts i think its the starter
xtowtruck
251
Tue Jun 29, 2010 12:06 pm
krewzlo View the latest post
New posts View first unread post Starter Woes...
13
431
