Post new thread Reply to topic  [ 14 posts ]
grafix
 Post subject: Help! Very odd issue
New postPosted: Wed May 30, 2007 11:41 pm
160
I have a 2000 454 chev/auto/ac/ loaded. Since I bought the truck I noticed a slight hesitation at low acceleration, a cough of sorts. I worked at a Chevy dealership and no mechanic could ever find a problem or explanation. Every once in awhile it would fail to start. It would fire and die immediately. I could walk away for 10 minutes and it would be fine.
I had new fuel pump put in it, plugs, wires, cap, rotor, fuel filter, etc. Truck has 119K. However, problem was never solved. Bout every few months it would have an episode where it wouldn't start.
Recently, for the past two weeks, it is now so regular on almost a daily basis. I am getting 50 psi at fuel rail and it is maintaining pressure after turned off. Fresh fuel filter again. But yet, daily almost it will fire and die immediately. I can smoke a cigarette and come back and it will fire, but then run like ass kinda sputtering along for a short while.
Dealership I am at now sat on it for over a week and gave me the "cannot duplicate" crap and didn't involve hardly any effort. I really need to figure this thing out if anyone has had a similar issue. All ideas are more than welcomed.
New postPosted: Wed May 30, 2007 11:50 pm
that almost sounds like what my blazer was doing (yea I know different vehicle,engine,year ect. ect.) what I found was the wires going to the injector were wore out and when they would move it would die or not start. if you grab them when its running and move them around a little you might get it to duplcate your symptoms
New postPosted: Thu May 31, 2007 1:43 am
so the feulrail is holding its pressure?
might be there's feul leaking through the injectors smothering the engine on initial startup but then again the dealer should've picked up on that
New postPosted: Thu May 31, 2007 8:29 am
49840
ok remember guys i had the same dam problem with mine.. 2000 chev 454!!!!!
i changed the fuel pump and all the crap you did too....
my problem went away once i changed all the power source wires going into the main fuse box under the hood... (from battery to box and so forth) dont know if thats your problem but it fixed mine.
once i took the old wires off the truck i stripped them and they looked ok on the outside but were very britle on the inside..
its cheap to try and hopefully that will fix it for you like it did for me
New postPosted: Thu May 31, 2007 9:57 am
looks like chevy goes cheap on materials again....
DragNasty
New postPosted: Thu May 31, 2007 11:34 am
1989 GMC sierra 3500
25170
Injectors are inside the intake on these motors.
New postPosted: Thu May 31, 2007 5:20 pm
^^^^^^^thats the way my blazer is also it's all in the plenum
burntup
New postPosted: Thu May 31, 2007 5:48 pm
1993 Chevrolet crew cab
4880
I had a friend having the same problem, it was his cam shaft positioning sensor that was the problem.
New postPosted: Thu May 31, 2007 9:08 pm
49840
sometimes my wifes thinks i have problems positioning my cam shaft.. i think my sensor is broke because it trys to slide into the wrong hole... :lol:
New postPosted: Thu May 31, 2007 10:07 pm
if you hit that hole it will really be lopey :lol:
grafix
New postPosted: Thu May 31, 2007 10:17 pm
160
Thanx guys for the input. I never thought of the wiring issue, but makes good sense since I have changed almost everything else .... lol.
Pressure at fuel rail maintains 50 psi both when able to start and not able to start.
New postPosted: Fri Jun 01, 2007 5:04 am
Oh thats just wrong.
New postPosted: Fri Jun 01, 2007 7:52 am
49840
:lol:
diabolic kustoms
New postPosted: Fri Jun 01, 2007 12:04 pm
1983 Ford Ranger
11820
I've had the same problem and it was the computer. what happened is that the fuel pump had a short and the draw caused my computer to malfuction. the problem was sporatic for about 6 months then it went dead..
souless and lovin it
No new posts HELP!!!! Truck wont start..
[ Go to pageGo to page: 1, 2, 3 ]
33
592
Sat Oct 09, 2010 9:09 pm
No new posts HELP!!! troubleshooting
svrdwgn
453
Wed Apr 21, 2010 8:33 pm
svrdwgn View the latest post
No new posts Help!
ben_shady1
13
384
Wed Sep 03, 2008 4:32 pm
New posts View first unread post Help! Very odd issue
grafix
13
1547
diabolic kustoms View the latest post
No new posts Help!! Fouled spark plugs.
21
1764
Tue Mar 06, 2007 8:31 am
No new posts HELP!!!, I HAVE AN A/C PROBLEM!!!
fuelrags
691
Mon Jul 03, 2006 3:54 pm
