Post new thread Reply to topic  [ 7 posts ]
abescustoms
 Post subject: having trouble starting after it sits
New postPosted: Wed Apr 16, 2008 5:06 pm
620
well this trouble is getting worse every day at first i thought it was the glow plug but noticed a lot of diesel on the side rail. so i checked all data and its considered cold start hard start the seal on the bleeder ar shot aqnd sucks air but the part numbers on there is not a good number at dealer, so i checked on dealers computer for those seals and they dont even show them i took them the whole assembly but still a no no, i went to a shit load of shops here where they repair diesel motors but told me the part that is stock on my motor they dont even come close. so now im stuck cranckin the shit out of my starter and broke a bolt off. was able to unscrew it off using the old bolt with a little pressure on it but now its sound weird like the teath dont line up , so tommorrow im going to buy ntwo new bolts and go from there but what the hell can i do to get a fastre start elecric fuel pump? new filter assembly which its discontinued, ???? :?
WE ARE HATED BY MANY, WANTED BY MANY, DISLIKED BY SOME, BUT CONFRONTED BY NONE!!!
ROLLERZ ONLY WORLDWIDE FAMILY
Jeffrodamis
New postPosted: Wed Apr 16, 2008 5:19 pm
1993 Chevrolet Crew Cab Dually
2960
dude what part are you needing.
"i aint no venereal fuddrucka"
abescustoms
New postPosted: Wed Apr 16, 2008 6:10 pm
620
PRETTY SURE THOSE DAMN O RING TYPE SEAL THAT GOES ON THE BLEEDER ON A SQUARE BODY AT THE FIREWALL ITS NOT AN O RING BUT SIMILAR 1/8 THICK BY LIKE A 1/4 WIDE
abescustoms
New postPosted: Wed Apr 16, 2008 6:12 pm
620
BUT SHOULD I ADD AN ELECTRIC FUEL PUMP TO PUMP UP THE DIESEL QUICKER
Jeffrodamis
New postPosted: Thu Apr 17, 2008 8:05 am
2960
try a reputable shop...i know youve taken it to a few shops but we have simular situations farely often here adn it really isnt an issue...the factory stuff should work fine. diesels dont like leaks very much lol
New postPosted: Thu Apr 17, 2008 2:33 pm
if a automotive diesel shop doesnt have it try a marine diesel shop , it allso might be that someone jerryrigged it that way to stop it leaking in the first place
abescustoms
New postPosted: Sat May 24, 2008 11:19 pm
620
okay im back after been out of town
well what i did is pushe a multyple o ring to seal the cock drain then sqeesed the plug back in still having the problem still leaking i changed the filter lement and still leaking so im thinking mayhave a crack or leak around the heat coil that warms up the diesel.. now the problem got worse it even harded to start. so i removed the glow plugs and one was dry and a lot or carburn burn the other are wet or diesel ( bad glow plugs ? ) ohh and i found at the wrecking yard a ford diesel with a oil filter style diesel filter so im thinking of adapting that kit onto my truck the heat coil in on the hardline will that work out for me better than the stock
New posts View first unread post having trouble starting after it sits
abescustoms
325
abescustoms View the latest post
