Post new thread Reply to topic  [ 20 posts ]  Go to page 1, 2  Next
 Post subject: Engine build time...
PostPosted: Thu Jun 12, 2008 11:03 am
67750
I’m gearing up to do some engine work on the dually and I would like to get a few opinions.
Basically, I want something hotter than your average one ton 454, but still perform reliably “as a truckâ€Â
RHMdually
PostPosted: Thu Jun 12, 2008 12:49 pm
1993 Chevrolet Crew Cab Dually
4950
well i personally wouldnt buy an edelbrock carb. had nothing but problems out of my freinds. and ive heard alot of similar stories. holley carbs all the way! you should be happy with a cam/intake/carb swap. i have a few more things done to mine but im getting 12 mpg. you may be able to get 15 mpgs. ill be intersted to see if you do.
PostPosted: Thu Jun 12, 2008 3:03 pm
1982 GMC classic
5420
well im on the other end i like the edelbroke carbs for street driving
thar thunder carbs work good the kits thay sell you would like .
i would get the prformer rpm air gap
and matching cam
you should get 400+ hp out of it
i did that with my 1st dually and loved it now if you want a monster let me know hehehheeh
go to compcams thay have a prog that helps you pic your cam and tells you you hp and touque
PostPosted: Thu Jun 12, 2008 3:05 pm
1982 GMC classic
5420
oo and campy this is the moter you realy want
http://s259.photobucket.com/albums/hh31 ... pic068.flv
you know thats realywhat you want you just dont have the guts
love ya man erik
PostPosted: Thu Jun 12, 2008 3:57 pm
67750
:lol:
Hey you said something about the Demon carbs and better fuel mileage. What's the deal with that?
PostPosted: Thu Jun 12, 2008 4:32 pm
1982 GMC classic
5420
not beter less and more power
PostPosted: Thu Jun 12, 2008 4:33 pm
1982 GMC classic
5420
butwe will see ill have a carb laying around after i put the deamon on
PostPosted: Fri Jun 13, 2008 6:11 am
Well when I got my dually my idea was to build a fairly high compression engine that would run on e85. It's octane is close to 105. You could just run an alcohol carb. At the time I could get e85 at several stations around me, I don't know how it would work for you. And it was typically .50 to .75 cents cheaper than gas. But as of late a few of the stations around here have been taking out their e85 pumps, so I don't know if the network is growing or shrinking at this time. My thought was you could build a pretty good motor and actually buy cheaper gas. But I'm not sure how e85 is in your area.
http://gasprices.mapquest.com/index.jsp
You can use that link to find if there are any e85 stations in your area.
Also in theory it should have lower emissions.
PostPosted: Fri Jun 13, 2008 5:59 pm
67750
Actually, after reading into it a bit, it seems like one of those Edelbrock kits for a big block will work like a charm.
http://www.edelbrock.com/automotive_new ... ages.shtml
PostPosted: Fri Jun 13, 2008 7:08 pm
1982 GMC classic
5420
ya it will you will like it get the heads allso and you will be super happy
PostPosted: Fri Jun 13, 2008 9:26 pm
seems like a good choice , a fuelinjectionsystem might give you better milage and better smog , it been a while ago but i believe edelbrock made those setups too they even burn the eprom for yah you need to fill in a form thatcomes with the kit with wat you done to the engine and the eprom gets send afterwarths to youre adress you just need to put it in the management box.
it will be harder to repair on the side of the road though but will hold its tune better once its correct
PostPosted: Fri Jun 13, 2008 11:24 pm
you want spects on mine
PostPosted: Mon Jun 16, 2008 9:50 am
67750
Send 'em.
...and yeah the heads are $899 each @ Jeg's, so I think I'm gonna pass for now.
HANGSLO
PostPosted: Mon Jun 16, 2008 10:27 am
990
A performer RPM kit would be the ticket. I have had both Edelbrock carbs and Holleys. For the street only where low end torque is important, I would pick the Edelbrock. I had a 95 Xtra cab with a mild 350 that ran mid 14's at the strip and got 18 mpg highway/13-14 mpg around town with the Edelbrock carb. I also had a Holley carb on it and it was much stronger and faster, but the mileage sucked, and with a box stock Holley, there are only so many adjustments that can be made.
You can adjust a Holley to get good power and mileage as well, but you have to buy one with adjustable circuits and it is not a cheap carb. The primaries on the Edelbrock are smaller than the secondaries and this helps with mileage and part throttle low end torque compared to the Holley's squarebore design.
With that combo, it should be a nice driver with good power, too.
anything that goes really fast and gets really shitty gas mileage has got to be cool ...
PostPosted: Mon Jun 16, 2008 10:53 am
1982 GMC classic
5420
look on ebay dude i found a set for 800 buxs
No new posts ENGINE PERFORMANCE UPGRADES?
530
Fri Oct 15, 2010 11:01 am
No new posts Engine bay clean up, deleting stuff????
58deluxerag
309
Wed Sep 22, 2010 4:23 pm
No new posts engine build
LMDGUY
324
Thu May 20, 2010 12:15 am
LMDGUY View the latest post
No new posts Engine Swap
duallylaid
297
Sat Nov 28, 2009 7:49 pm
duallylaid View the latest post
No new posts couple of 454 engine questions.
suksgas
572
Thu Sep 03, 2009 6:51 pm
suksgas View the latest post
No new posts engine removal
LILTWIN
213
Wed Jun 10, 2009 7:13 am
448
Wed May 13, 2009 1:15 pm
No new posts engine rebuild kits
19
525
Mon May 04, 2009 7:58 am
No new posts Engine Start
267
Tue Jan 13, 2009 6:13 pm
No new posts Engine build time...
19
702
Fri Jun 20, 2008 7:23 pm
skidrow View the latest post
