Post new thread Reply to topic  [ 5 posts ]
LMDGUY
 Post subject: engine build
New postPosted: Wed May 19, 2010 11:07 am
440
So my 95 chevy dually 454 has a knock. Gonna pull the engine and send it out for a rebuild. Just wondering what upgrades I should do? Or what anyone else has done... Machinest said upgrade to a emmision safe RV cam, bigger valves and some clean up on the heads.
Joe M.
1995 3500 2wd, 454, auto,aka "The Hill Billy Hauler"
myspace.com/lmdguy
http://severedties.com/SeveredTies/
http://www.autocorekustoms.com/
 Post subject: Re: engine build
New postPosted: Wed May 19, 2010 6:22 pm
1986 Chevrolet Crew Cab Dually
4830
The stock peanut port heads are the biggest bottle neck on these motors. I just picked up a set "worked" 781 large oval port heads for my square.
'86 Crew Cab-Cam+Bolt-ons BBC,TH400 G/V O/D Equipped, Built C&C, 6/10 on 24's
LMDGUY
New postPosted: Wed May 19, 2010 7:45 pm
440
so def some head work then?
Joe M.
myspace.com/lmdguy
New postPosted: Wed May 19, 2010 7:56 pm
4830
Yes, if you can't pick up a set of 049's or 781's. The stock compression is also very low, sometimes less than 8:1.
LMDGUY
New postPosted: Thu May 20, 2010 12:15 am
440
well come to find out I was bored when I got home today and decided to run some combustion cleaner thru the engine too see if it would help. The truck had been sitting for alil over a year.. it cleared up the noise. My tech had said it proably had a sticky valve. Need to pull codes to see whats causing the check engine light still. But my friend has a 454 out of a 96 dually that im goin to pick up and start building at 220k miles i can trust it too tow across the desert
Joe M.
myspace.com/lmdguy
No new posts ENGINE PERFORMANCE UPGRADES?
475
Fri Oct 15, 2010 11:01 am
No new posts Engine bay clean up, deleting stuff????
58deluxerag
278
Wed Sep 22, 2010 4:23 pm
New posts View first unread post engine build
LMDGUY
302
LMDGUY View the latest post
No new posts Engine Swap
duallylaid
269
Sat Nov 28, 2009 7:49 pm
duallylaid View the latest post
No new posts couple of 454 engine questions.
suksgas
530
Thu Sep 03, 2009 6:51 pm
suksgas View the latest post
No new posts engine removal
LILTWIN
196
Wed Jun 10, 2009 7:13 am
No new posts engine build
388
Wed May 13, 2009 1:15 pm
No new posts engine rebuild kits
19
457
Mon May 04, 2009 7:58 am
No new posts Engine Start
231
Tue Jan 13, 2009 6:13 pm
No new posts Engine build time...
19
655
Fri Jun 20, 2008 7:23 pm
skidrow View the latest post
Users browsing this forum: No registered users and 13 guests
