Post new thread Reply to topic  [ 29 posts ]  Go to page 1, 2  Next
58deluxerag
 Post subject: Electrical nightmare :(
PostPosted: Sat Sep 11, 2010 4:13 pm
1993 Chevrolet Crew Cab Dually
1860
Looking for some advice, dash gauges are going crazy, needles going back and forth. Sometimes hit a bump and they go back to normal fuction. Power windows & locks don't work either, when I push a button on the door, the gauges go crazy. and the door niether unlocks or locks and the windows don't move. My truck doesn't have daytime running lights, but for some reason my brights stay on really dim all the time, when I turn the lights on and use the brights, one goes out.
There is a bunch of rigged up wiring, thinking of undoing it all and trying to start over. I have a factory service manual coming here shortly, hoping that helps a bit. All sound like grounding issues?
-Corey
shpaint1
 Post subject: Re: Electrical nightmare :(
PostPosted: Sat Sep 11, 2010 10:26 pm
2002 Ford F350
620
yes i would say its a grounding issue, make sure the ground link between the cab and frame is good and the one between the battery and frame
58deluxerag
PostPosted: Sat Sep 11, 2010 10:41 pm
1860
Check and check, both ground cables are there and connected.
-Corey
PostPosted: Sun Sep 12, 2010 7:44 am
49840
gunna sound crazy but you might want to CHANGE your main ground from the battery to the chassis... sometimes they will actually corrode(spelling?) inside the insulation so it will look good but actually be loosing ground....
burntup
PostPosted: Sun Sep 12, 2010 8:53 am
1993 Chevrolet crew cab
4880
have you taken the seats out? the reason I ask is I had problems once when the power wire for the seats got pinched between the seat and the cab floor. I know that sounds crazy
58deluxerag
PostPosted: Sun Sep 12, 2010 4:12 pm
1860
Ground cable looks new, but I'll try that.
Burntup, I think it has defferent front seats in it now from when you had it. has some '95 and later buckets, power doesn't work on them, don't even think it's hooked up. I'll take a look though.
Sucks when I peek around this truck all I see is problems. yesterday, found a air line pinched off with some vice-grips, that's when I went inside and quit working on it. A little bummed I gave what money I did for this turd. All I can tell myself is, "it'll be good eventually." lol
-Corey
PostPosted: Mon Sep 13, 2010 9:40 am
49260
More than likely a ground problem somewhere in the wiring. I had a 94 Cheyv that did the same and it ended up being the main ground and one of the many grounds behind the dash.
58deluxerag
PostPosted: Mon Sep 13, 2010 10:21 am
1860
Still waiting on my factory service manual before I dive head first into it, but I did find the main harness resting and melted on the left side exhaust header. Though that was really awesome. Should have been relocated after the bodydrop. Not my original work, I just get to fix it. Surprised this truck has made it this far like that.
-Corey
burntup
PostPosted: Mon Sep 13, 2010 3:59 pm
4880
when I got rid of it I had just put some Pontiac Sunfire seats in it. they sat real low to the floor. Do you remember the guys name you bought it from?
58deluxerag
PostPosted: Mon Sep 13, 2010 8:02 pm
1860
Buddy in Orlando, Randy Frederick.
Got my service manual today, not many good wiring diagrams in there. Anyone got some they can maybe scan and copy for me? Started tearing the dash apart and removing unneeded wires.
-Corey
burntup
PostPosted: Mon Sep 13, 2010 9:27 pm
4880
that is not the guy I sold it too
58deluxerag
PostPosted: Mon Sep 13, 2010 10:14 pm
1860
Think he got it from this guy, cambercrewcab. http://duallyscene.com/forums/memberlist.php?mode=viewprofile&u=2584
-Corey
58deluxerag
PostPosted: Thu Sep 16, 2010 7:44 pm
1860
Alright got the dash out. Not seeing anything wrong. Getting rid of some of the previous owners hacks and extra wires that didn't belong. Everything is fine until I try to use more than one accesory at a time. Do I need a new/bigger alternator?
-Corey
58deluxerag
PostPosted: Fri Sep 17, 2010 2:35 pm
1860
Ordered the actual Factory electrical wiring diagram & diagnosis manual. See if that's any help.
Lights were dim when truck was on and lights turned off, messed with the grounds and now they are totally off when the switch is off. EXCEPT when the a/c is turned to medium and high. Really wish I was an auto electrician.
-Corey
PostPosted: Fri Sep 17, 2010 6:59 pm
13010
I would get a harness from the bone yard and start over
No new posts Electrical nightmare :(
58deluxerag
28
917
Thu Sep 23, 2010 10:30 am
xtowtruck View the latest post
No new posts Couple of quick none dually electrical questions.
210
Mon Aug 10, 2009 12:57 pm
krewzlo View the latest post
