Post new thread Reply to topic  [ 23 posts ]  Go to page 1, 2  Next
psylent
 Post subject: EDC information - BIG AIR in no time
PostPosted: Sat Jan 22, 2011 1:52 am
1994 Chevrolet crew cab dually
2130
I got a PM about my engine driven compressor, so I figured I would share.
So check this out, my compressor is out of an older volvo, I want to say an 86 but I will get the specifics from my buddy as he is the one who set me up with it. When I purchased my truck it already had the EDC but I ended up throwing a rod in it and had to replace it.
This is what mine looks like...Image... and its dual piston... Wooohooo
I picked it up at the wrecking yard for $50. you will have to do a few things depending on your setup. If your running a v-belt no worries the one I have come standard with a v-belt setup; however, I have a serpentine belt so I had to get it modded by a machinist, also run a longer belt.
Mounting is takes a little fab work making your own brackets, mostly out of flat bar bent to perfection.
This compressor I am running is 9.1 cfm @ 3k rpm. It kicks the shit out of the viair 380 in my car as it is .9 cfm constant when the engine is running.
Here is tons of information on EDCs http://www.jedi.com/obiwan/jeep/york_id.html Look around... The website will describe a mod the will keep the oil from going into your air system as well as how to get the pully off without effing up the clutch system.
I will post some close ups of my setup tomorrow.
Four doors fit more Whores!
LUV2XCLR8
 Post subject: Re: EDC information - BIG AIR in no time
PostPosted: Sat Jan 22, 2011 6:26 am
2000 GMC Crew Cab
6450
I had one of those for my 71 Jimmy that
I sold. Never got it mounted but like you
said they have very good output on them.
PROJECT: "SQ VET" 72 BLAZER 2WD
TOW RIG: "GAS HOG" Y2K GMC 3500
Owner/Admin "TN Classic Truck Club"
................... _______
......._________|___|___\_____
......|__((O))__|___|___|_(O)_|
PostPosted: Sat Jan 22, 2011 9:51 pm
1998 Chevrolet HUGE OL TANK
4120
man i need to hurry up and do this to mine. it sucks sitting there for like 10 mins to fill up.... ugggghhh
psylent
PostPosted: Sun Jan 23, 2011 2:14 am
2130
Here is mine in my truck...
LUV2XCLR8
PostPosted: Sun Jan 23, 2011 7:39 am
2000 GMC Crew Cab
6450
Sweet !!!
PostPosted: Sun Jan 23, 2011 12:24 pm
4120
damn im jealous.... i want one... :(
KBLR ELF
PostPosted: Sun Jan 23, 2011 1:38 pm
1420
same one on mine just a tip go to the bone yard look for a v6 s-10 like 96-97 take the p/s fill tube out and the gromet for it you can cut the tube down shorter and dont have to fight to get to the p/s fill to check it or add fluid just a tip to help they are bad ass and quiet
NO REST FOR THE WICKED TILL WE CLOSE OUR EYES FOR GOOD
PostPosted: Sun Jan 23, 2011 8:09 pm
13160
How are you setting up the oiling so the compressor doesn't croak?
psylent
PostPosted: Sun Jan 23, 2011 9:23 pm
2130
Unless most A/C compressors that circulate the oil these actually have a reservoir for the oil. You do have to keep an eye on the oil and sometimes add a little but it is easy. There is a fill hole on either side.
PostPosted: Sun Jan 23, 2011 9:53 pm
1999 Chevrolet crew cab
11840
I have a York 209 Big Block kit in my truck now. But pulley or pulley bearings are going out I believe cause its starting to squeak. Can order new pulley for it, but I have a brand new York 210 in my garage I think I am going to upgrade to.
sparkys-crewcab
PostPosted: Mon Jan 24, 2011 4:40 am
1977 GMC sierra 3500
5840
have any of you guys thought about finding a way to run a york compressors off a 12 volt motor?
you could buy a winch and rob the 12v motor.(harbor freight has them cheap) take the clutch off the york. weld up a "box" out of steel to mount the york on one side. the 12 volt motor on the other. the only hard thing is trying to find a way to couple both shafts together..maybe get a 2 inch round steel bar and drill out the ends to fit both shafts...??? or a mini universal joint????
i know a company called oasis compressors already has this setup you can buy off the shelf. (cheapest used i found was 600 bucks)
i think i may do my york this way instead of mounting it to my engine. :idea:
"My dreams are all dead and buried. Sometimes i wish the sun would just explode.
When god comes and calls me to his kingdom. i'll take all you sons of biatches when i go...lett'er blow-ooohhhoo"
DO NOT TOUCH THE TRIM!
loweredd
PostPosted: Tue Jan 25, 2011 11:14 am
660
The only downside to the York IS that if the engine isn't running, you are S.O.L. Wife just had the fuel pump die on our new to us dually, and the 480s that were under the bed are so worn out, it took a couple hours with jumpers cables on to air it up to tow it to town. Sucks, cause I was in Houston, 1000 miles from home when it happened. Then the York took a crap a couple days later. :x
PostPosted: Tue Jan 25, 2011 11:18 am
49260
We use the York 209 or 210s on most trucks and then have a 12v comp somewhere on the truck just for emergencies. I think you can get the York comps at the part stores for around $200 and they pulleys are another $50 or so.
loweredd
PostPosted: Tue Jan 25, 2011 11:48 am
660
Picked up a rebuilt at Oh Reallys for 145.
PostPosted: Tue Jan 25, 2011 12:20 pm
4120
which one 209 or 210?
And part number?
No new posts EDC information - BIG AIR in no time
psylent
22
989
Sat Jan 29, 2011 1:06 am
cron
