Post new thread Reply to topic  [ 7 posts ]
CokeZero
 Post subject: Çhevy 6.5 Turbo Diesel Question [with pic]
New postPosted: Sat Sep 17, 2011 3:26 pm
380
Total noob to diesels, what does this goto/do?
 Post subject: Re: Çhevy 6.5 Turbo Diesel Question [with pic]
New postPosted: Sat Sep 17, 2011 8:14 pm
13160
That is probably the bleeder valve for the fuel system. Not much of a diesel guy so I'm taking a wild-ass guess here. :mrgreen:
You would use it to bleed off pressure before replacing the filter, or for getting air out after replacing the filter or running out of fuel.
comegetsome
New postPosted: Sat Sep 17, 2011 9:02 pm
3170
looks like a valve we run on our tractors....plumbed into coolant hoses to turn water flow off to heater core in the summer months when its not needed....but without seeing where the other end of the hoses go i cant tell ya for sure....so just a guess also
New postPosted: Sun Sep 18, 2011 4:27 pm
13160
I'm betting that hose off to the passenger side is just sitting there, right? If you turn that valve have a container over the end of the hose, betcha diesel comes out. :mrgreen:
CokeZero
New postPosted: Sun Sep 18, 2011 5:29 pm
380
Apparently it's a water-drain off petcock
you can see if there's any water collected in your fuel. It also serves a purpose in checking your lift pump, with engine running open petcock all the way making sure you have something to drain fuel into(like a 1 gallon or bigger jug), if the engine changes idle speed or goes dead it means your lift pump(fuel pump) is going out.
CokeZero
New postPosted: Tue Sep 20, 2011 11:31 am
380
New Problem!
97 6.5 crew cab dually and I need ideas on my problem. First off let me state the tranny was rebuilt 2 years ago so I don't think thats the problem.
Sometimes when I'm driving and I take off from a stop and give it alot of gas it will barely pull (Won't squat and go) accelerates slow and if you put it too the floor the rpms jump up in overdrive but it doesn't pull any faster.
I have a crappy faze boost gauge hooked up running to a fitting on the top of the intake. when turned off it sits below 0. so its hard for me to get an accurate reading. but when I looked at the boost gauge when its doing the problem I stated above and I floor it, the gauge reads backwards a little (like its going into vac)
So I'm thinking its some sort of boost leak but I'm not sure. It doesn't do it all the times. just sometimes. and seems only after ive been driving a bit. Any ideas?
Thanks in advance!
CokeZero
New postPosted: Wed Sep 28, 2011 12:41 am
380
Well shit, Noticed a drip below the passenger door. Looked up from bottom, coming from firewall. Think my heater core is fucked :/
New posts View first unread post Çhevy 6.5 Turbo Diesel Question [with pic]
CokeZero
479
CokeZero View the latest post
No new posts pros and cons of the chevy 6.0 ltr
bdydrppup
1082
Sun Dec 27, 2009 9:18 pm
comegetsome View the latest post
No new posts 1993 chevy with 6.5?
layddually
302
Tue Jan 27, 2009 9:39 pm
No new posts Headers for a 99 Chevy 1 ton w/ 454...?
387
Mon Oct 22, 2007 10:42 pm
No new posts over heated 89 chevy with 454?
[ Go to pageGo to page: 1, 2, 3 ]
layddually
32
2828
Sun Jul 22, 2007 2:44 am
