Post new thread Reply to topic  [ 56 posts ]  Go to page Previous  1, 2, 3, 4
ARAMP1
New postPosted: Wed Mar 26, 2008 11:43 pm
570
I'm building a 4-71 which would normally weigh in at 2100 lbs. But, I'm using an aluminum block, front and rear plates, front cover and bellhousing. It should weigh in around 1300lbs. I'll be shooting for 300-350 hp and around 700-800 ft-lbs. We'll see.
Right now, I've got a 13 speed double overdrive roadranger, but I might just use a ZF6 out of a newer Ford Superduty for easier shifting.
NUKLHEADTATTOO
New postPosted: Thu Mar 27, 2008 3:30 pm
1988 GMC sierra 3500
2870
Im looking at 4-53t...what tranny would be best for me?I seen some swaps and they had a Allison 4 speed...like i said i plan on driving it a lot and trailering??Id like to start picking up parts soon.
ARAMP1
New postPosted: Fri Mar 28, 2008 4:53 pm
570
I really don't know allison transmissions, but you'd definitely want one with an overdrive. I think most of those older heavy duty 4 speeds are not overdrives.
New postPosted: Fri Mar 28, 2008 5:12 pm
The common allison 5 speed is the at545, no it doesn't have overdrive.
http://www.atlanticdda.com/transmissions/
That might help. The md3060 is the one I would like to put behind my 454.
New postPosted: Thu Jun 12, 2008 9:00 pm
look wat i found :
http://www.youtube.com/watch?v=mkqCOHCT ... re=related
New postPosted: Fri Jun 13, 2008 10:27 am
67750
Sweet.
Seems like the 4-53 is a more common swap in the pickups.
New postPosted: Fri Jun 13, 2008 1:24 pm
http://www.youtube.com/watch?v=E0o1o5W_f6o&NR=1
here's another one 4 speed with doubler in there too ...... from the look of it they might've installed a bodyliftkit to get the engine under the hood
New postPosted: Fri Jun 13, 2008 3:25 pm
67750
Dude! That's pretty sweet.
therealAzDon
New postPosted: Tue Sep 02, 2008 10:01 pm
180
I've been truckin for 30 years and my advice regarding 2-stroke detroits... fuggidaboutit!
Improved power-to-weight? NO! Improved fuel mileage? NO! The power and acceleration band will make you wish you had your big-block back! As diesels go, 2-stroke detroits ARE NOT torque monsters and must be wound up to deliver anything at all. Where most of the modern-era truck engines top out at 1800 rpm and lug down near 1000, those detroits run between 1500 and 2200 rpm.
There are WAY BETTER engines to use if you want to do a truck engine, but you should know that if you take this kind of project on, you will be seriously overloading the suspension, brakes, and front weight bias. Before deciding to do this, you should crawl under a big rig or even a medium duty AMERICAN MADE city delivery truck and scope out the size of the transmission, driveshaft, and differential that goes behind a truck diesel.
It's my feeling that you will hafta cut out your firewall and floor to get the stuff in there. After you are done gettin it in and hooked to a spliced driveshaft, I think you'll have an overpowered beast that won't handle, won't stop, and will be bottomed on the front suspension..... Before you get these problems sorted out, it's likely that your diff will be broken, as well!
My advice, ig you still wanna do a diesel swap is to find a wrecked dually diesel pickup and salvage everything and learn,learn,learn!
Truck engines better suited to what you're doing are the 3208 Cat v-8 and many of the newer/smaller diesels made for new-era medium duty. You could also check out some of the foriegn isuzu/iveco/mercedes/volvo offerings.
IMHO, you'll spend so much on the project that you'll never get it back in energy cost savings!
therealAzDon
180
And I didn't even mention how much oil detroits leak/burn!
New postPosted: Wed Sep 03, 2008 1:18 am
:lol: ^^^thats what I was thinking about campy if dont like all the sand I left on your driveway your sure as hell not going to like the oil coating its going to get :lol:
and far as taking a blower off a diesel and puting it on a gas engine if I remember right you need to do some impeller work and change a couple of bushings to bearings and there is som machine work that needs to be done on the front snout their is quiet a bit of work involved in that swap a diesel blower is not put together to turn the RPM's that a gas eingine will
New posts View first unread post 6v53 Detroit
[ Go to pageGo to page: 1, 2, 3, 4 ]
55
2111
