Post new thread Reply to topic  [ 51 posts ]  Go to page 1, 2, 3, 4  Next
rnonelower
 Post subject: 454 hard to start
New postPosted: Mon Sep 22, 2008 4:37 pm
1999 Chevrolet Crew Cab Dually
2360
does anyone on hear have any ideas on what might be the problem I have a 99 454 with 87k and up until it hit 75k it would start after 1 or 2 cranks super fast start know I have to grind on that shit for like 10 min. to get it to fire off any help would be great really starting to piss me off thought about new plugs but the dealer told me that the factory ones were good for 100 thous. are they wrong or should I look at some other culprete
New postPosted: Mon Sep 22, 2008 6:17 pm
72370
what bout fuel? got pressure? ever replaced fuel filter?
New postPosted: Mon Sep 22, 2008 6:44 pm
Online
49450
i had a 2000 and it did the same thing. i change the fuel pump and it fixed it. the pumps just get weak and will still work for alittle while longer but the pressure is just low enough to affect it alittle.
brianbgboy
New postPosted: Mon Sep 22, 2008 6:47 pm
2000 Chevrolet crew cab dually
5760
if it runs good after it starts without bogging any, it needs injectors. the factory injectors will leak down when the engine isnt running, and when you are trying to start it, they have air in them.to see if this is the problem, hook up your fuel pressure guage up, crank her up. you should have at least 55 psi when running. kill the engine and watch to see how long it takes for the pressure to drop off. if it drops down more than 10 psi within say 3 minutes, you have a leaky injector. i replace all the leaking stockers with the bosch injectors from www.fiveomotorsports.com and they really wake these trucks up big time. good luck with it, later, brian
looks like me and campy are friends after all, but i still love the shitbox body better!!!!!!!
rnonelower
New postPosted: Tue Sep 23, 2008 8:37 am
2360
talked to a buddy of mine last night that has a 98 x-cab 4wd he said that the fuel pressure regulator might be bad and leaking off has anyone heard of that and can that be checked like the injectors
03on22s
New postPosted: Tue Sep 23, 2008 9:09 am
830
Which injectors on that site work on the Vortec 454?
98crewcab
New postPosted: Tue Sep 23, 2008 10:28 am
4850
my money $$$ is on the fuel pump, seen lots of them go out or weaken.
its going to stop on you soon
Dual-lay
New postPosted: Tue Sep 23, 2008 11:48 am
110
i had a 96 crew cab that did the same and my cousins truck did the same. it starts fine when its cold runs like a top but when you turn it off and try to start it "hot" it's a bitch and cranks like crazy! i did the fuel pump still did it, checked the regulator it was fine injector were cool, it's wasn't the fuel system. it was the ignition switch (the key) it goes bad after starting it so many times and it doen't help getting pissed and pushing harder on it. i replaced the switch it in both trucks fixed it. it sounds worng (it said the samething) but after looking and looking and replacing this and that someone told me to change it and i finaly did. no more problems.
New postPosted: Tue Sep 23, 2008 11:50 am
1999 Chevrolet crew cab
11800
Mine is a 99 and does the exact same thing. And I have replaced the fuel pump and filter. Which injectors specifically did you get from that site..? What you described your truck doing w/ the air in the injectors is exactly what mine is doing.
03on22s
New postPosted: Tue Sep 23, 2008 12:06 pm
830
This sounds like a common problem, cause mine does it too.
brianbgboy
New postPosted: Tue Sep 23, 2008 9:46 pm
5760
the ONLY way to correctly diagnose this is the way i posted earlier. if the fuel pressure drops down when the engine is killed, it WILL BE the injectors. the fuel pressure regulator will cause stalling when running, like the fuel pump will. the fuel pumps in these go out more often due to heat from overworking to push fuel through faulty injectors, and because it has to keep repriming the air out of them every time you start the engine. if you have good pressure when idleing, the injectors are screwing you up. these gave me more power, better starting, and waaaaaaaaaaayyyy better mileage.http://www.fiveomotorsport.com/Injector ... .asp#bosch they will be the yellow set on the left of the screen. i work on these things everyday, and can tell you the gm multec injectors are the worst design ever. later, brian
brianbgboy
New postPosted: Tue Sep 23, 2008 9:50 pm
5760
sorry!!! just copy and paste the link fella's :oops:
98crewcab
New postPosted: Tue Sep 23, 2008 10:19 pm
4850
brianbgboy.....I assume the truck will still pass emmision testing?with the yellow injectors?
I have to smog my truck every two years....
brianbgboy
New postPosted: Tue Sep 23, 2008 11:03 pm
5760
yes sir. it will pass perfect. the stock injectors use a pintle(small needle) in the center thay lets the fuel spray when it opens. the bosch have four holes in them that mists the fuel. you get 100% better atomization, which leads to ALL the fuel dropped into the cylinder being used instead of just evaporation before it even gets into the cylinder. the yellow's were by far the best investment i made to my engine. later, brian
New postPosted: Tue Sep 23, 2008 11:13 pm
brian you've got the gerbal on the run in my head about my whole fuelpressure problem that I'M DEALING WITH and I'm starting to fall into the thought of bigger and more pressure is better :lol:
on a side thought if I bring up my pressure on the stock gm injectors to lets say 15psi wont that help atomnize the fuel better
No new posts 86 dually 454 ca emission help
olsskooltandem
218
Thu Sep 16, 2010 9:55 pm
AlbertaAMX View the latest post
No new posts anyone put a gear drive set on there 454?
WellBilt Kustoms
356
Sat Jan 23, 2010 3:41 am
comegetsome View the latest post
No new posts 454 and 700r?
ministock72
381
Tue Dec 29, 2009 10:59 am
No new posts couple of 454 engine questions.
suksgas
530
Thu Sep 03, 2009 6:51 pm
suksgas View the latest post
No new posts 454 vs. 350 fuel mileage
Randy Curran
18
2306
Mon Nov 02, 2009 9:03 pm
low4life View the latest post
No new posts 305 on 454 dually
823500blackbeast
352
Fri May 01, 2009 6:40 am
liljlowrider View the latest post
No new posts 4l80e behind my old 454
641
Thu Mar 05, 2009 1:39 pm
No new posts shorty or mid lenght headers for 454/square
bdydrppup
306
Mon Jan 19, 2009 10:59 pm
skidrow View the latest post
No new posts What compression ratio for 87 octane on my '86 454?
243
Tue Oct 14, 2008 10:19 pm
brianbgboy View the latest post
New posts View first unread post 454 hard to start
[ Go to pageGo to page: 1, 2, 3, 4 ]
rnonelower
50
2580
Thu Jul 22, 2010 11:30 am
Users browsing this forum: No registered users and 12 guests
cron
