Post new thread Reply to topic  [ 7 posts ]
LOWBOY
 Post subject: 350 TIMING
New postPosted: Fri Apr 14, 2006 11:05 am
1280
JUST FINISHED REBUILDING MY 350 IN MY DUECE. WENT WITH A LITTLE BIGGER CAM, AND THATS WHERE MY QUESTION COMES IN. ITS BASICALLY ALL 94 DRIVE TRAIN AND ELECTRICAL COMPUTER ETC. TO TIME YOU HAVE TO DISCONECT THE TIMING CONNNECTOR, SWITCH WHAT EVER YOU WANNA CALL IT. IT WONT RUN TIMED TO "0". AT THIS POINT I AM ABOUT 6 DEGREES. IT STARTS FINE. IDLES FINE. ALTHOUGH LOW (FROM THE CAM), BUT IT STILL FEELS A LITTLE BIT OFF. ACCELERATION. POINT OF MY LONG WINDED STATEMENT IS, IF ANYONE HAS OR HAD A SIMILAR SET UP, WHAT YOU SET YOUR TIMING AT.
New postPosted: Fri Apr 14, 2006 12:59 pm
pitch the timing light and time it by ear
but now that I read your question a little closer your ecm might be having a fit with the cam
LOWBOY
New postPosted: Fri Apr 14, 2006 1:57 pm
1280
THE CAM WAS SELECTED WITH THE COMPUTER IN MIND. VERY MILD. VERY VERY MILD. IM NOT RELYING ON THE TIMING LIGHT TOTALLY, AS YOU SAY DOING IT BY EAR. IT STARTS GREAT. RUNS GOOD. JUST ON ACCELERATION, THERE SEEMS A REAL SLIGH HESITATION, BUT THEN AGAIN I MAY BE READING INTO NOTHING.
ILLEGAL REGALâ„¢
New postPosted: Fri Apr 14, 2006 6:16 pm
2130
Time by ear is a great way to start, get it runnin good then put a gun on it to see exactly what ya got.
Whats the specs on the cam?
HANGSLO
New postPosted: Sat Apr 15, 2006 8:27 am
990
If it is still a TBI you may want to look into a chip and/or fuel pressure regulator. The TBI setups are very senstive to cam (vacuum) changes. The computer uses speed density algorithms to determine the correct fuel map and spark curve. If the cam drops any vacuum AT ALL, the computer sees lower vacuum and assumes it is already under a load and consequently wont add in as much throttle (acceleration) enrichment, because it already assumes you are "working". Just changing the compression ratio 1 point on those motors can cause the motor to run lean ... just something to think about.
Once you disconnect the timing lead (tan/black wire) you can advance the timing a little, and it should stay there as a baseline for the computer to register off of.
BTW, there are many computer friendly cams out there, but if your cam is much over 204 degrees on the intake, it is too big for a stock computer to be optimal.
anything that goes really fast and gets really shitty gas mileage has got to be cool ...
LOWBOY
New postPosted: Fri Apr 28, 2006 12:11 am
1280
GOT A HYPERTECH CHIP. DIDNT CHANGE A DAMN THING. TALKED TO THE PEOPLE AT HYPERTECH, SAID I WOULD NEED SOMEONE TO CUSTOM BUILD A CHIP FOR THE TRUCK. THAT THE CHIPS THEY MAKE ARE DESIGN FOR STOCK APPLICATIONS ONLY. THE CAM THAT IS IN THE TRUCK IS "COMPUTER FRIENDLY". RUNS GREAT EXCEPT IT IDLES WAY TO LOW IN GEAR AFTER IT IS WARMED UP. SO ANY OTHER IDEAS FROM ANY ONE, AND DOES ANY ONE KNOW OF A PLACE THAT CAN MAKE A CUSTOM CHIP?
ILLEGAL REGALâ„¢
New postPosted: Thu May 11, 2006 6:53 pm
2130
Try ASSC racing, they're by me but maybe they can do 1 for ya or send ya somewhere close by you.
http://www.asscracing.com/
No new posts vortec 350 swap
dailydriven
444
Fri Jan 14, 2011 10:44 am
lockone View the latest post
No new posts 454 vs. 350 fuel mileage
Randy Curran
18
2610
Mon Nov 02, 2009 9:03 pm
low4life View the latest post
No new posts fuel injected 350 in a square?
bdydrppup
18
711
Fri Jan 23, 2009 5:50 pm
bdydrppup View the latest post
No new posts 350 mounts
Str8Ugly
177
Fri Nov 21, 2008 3:09 pm
Str8Ugly View the latest post
No new posts 2000 Dually w/350 Gas mileage?
1LowLeSabre
323
Wed Apr 23, 2008 10:38 pm
1LowLeSabre View the latest post
No new posts my whored out 350
B DIME
262
Fri Jan 18, 2008 10:18 pm
BowtieCowboy View the latest post
No new posts 95 3500 with 350 ?'s
KatFish
522
Thu Oct 04, 2007 5:03 pm
KatFish View the latest post
No new posts Starting Issue, '87 TBI 350
kdubaz
746
Mon Jun 04, 2007 9:59 am
No new posts Cooling fan on a bd c3500
859
Tue Jul 18, 2006 4:44 pm
//NC\\Tricky View the latest post
New posts View first unread post 350 TIMING
LOWBOY
651
ILLEGAL REGALâ„¢ View the latest post
