Post new thread Reply to topic  [ 15 posts ]
ARAMP1
 Post subject: Sub Box Build 1990 Silverado
New postPosted: Mon Dec 15, 2008 11:11 pm
570
Okay, so a while back, the el-cheapo pioneer 8 inch sub and 40 watt amp that were in my truck when I bought it several years ago were stolen. So, I've decided to build the system that I always wanted in my truck. It's nothing over the top, just a single sub and two amps, one for the 4 speakers and 1 for the sub.
Here's my truck. It's a 1990 Chevrolet Silverado.
As anyone with a pickup truck knows, there isn't as much room behind the seat. With only a couple inches to play with, I was going to have to go with a shallow mount sub. I chose a Kicker 12" CVT shallow mount.
I ran painters tape all across the back wall and started laying fiberglass. This is messy as hell.
After getting a good few layers of a back and a floor of the speaker box, I cut out the internal walls of the speaker box and mounted the speaker ring. You can start to see how the speaker box will be split up. I'll have the subwoofer in the middle, the amps on one side and a small storage/glove box on the other to hold miscellaneous items such as jumper cables, tools, etc.
Stretching an old t-shirt over the sub ring for the first layer of resin. I did this for each of the three areas (sub, amp, and storage sides)
Here's the finished product after several layers of fiberglass and some body filler.
You can see how the amps will be mounted from behind in this picture.
After hours of sanding and more body filler and sanding and more body filler, and sanding some more, it was ready for paint.
Well, I decided not to paint it and drop it off at the local LineX dealer. $60 to coat the whole thing and it will be much more durable than any paint I could use. Here's the end result.
Here's what it looks like with the sub, amps, and storage door on it. This is just the test fitting. Everything needs to be wired and I need to find some hinges and a lock for the storage compartment door.
This was my first fiberglass effort. I think it turned out great, so I'll be doing a lot more. I can't wait to get it all wired up and hear it thump, but it's cold as hell outside, so I'll be holding off for a while.
New postPosted: Tue Dec 16, 2008 12:25 am
1999 Chevrolet crew cab
11840
That is sick!!! Much props for that one.(especially if its your 1st fiberglass one)
blackout
New postPosted: Tue Dec 16, 2008 12:27 am
1999 Ford f350 dually
300
good job , dig the diamond plate and line x
Diverse customS Image
98crewcab
New postPosted: Tue Dec 16, 2008 12:56 am
4850
8) nice job, i enjoy the pictures, box looks awsome !!!!
A+ for you
New postPosted: Tue Dec 16, 2008 7:43 am
49840
great job man.. love the box.. especially for your first one. love th diamond plate storage box. very good way to use all the room you had.
New postPosted: Tue Dec 16, 2008 10:44 am
67730
DUDE!!! That's slick!
That is nice.
low1ton
New postPosted: Tue Dec 16, 2008 10:54 am
1988 Chevrolet R30
1770
Turned out awesome, especially for your first attempt. You should make several of them and sell the box for all of us untalented people who want a box behind our seat!
WIDER IS BETTER! (trucks only)
raymondsage
New postPosted: Tue Dec 16, 2008 12:19 pm
5850
I do it for a living and from a pro i gotta say that is a great looking box. You got some serious talent.
ARAMP1
New postPosted: Tue Dec 16, 2008 9:09 pm
570
HA! I thought about it for a half of a second. I'd never be able to sell them for enough to make back my time. My respect for people who do it for a living increased exponentially the further I got into this project.
ARAMP1
New postPosted: Tue Dec 16, 2008 9:13 pm
570
Thanks for the props, guys. Since it turned out even better than I thought it would, I'll be doing side speaker boxes that will fit from the sub box to the cab corners that will hold component speakers. They will be LineXed too. I'm also planning an overhead console that will hold a CB radio and a drop down DVD flatpannel among other things.
New postPosted: Tue Dec 16, 2008 11:09 pm
great job on that one , you might want to get a few strips of sound deadner between the back of the box and the whall in case it flexes ever so slightly .
you better bolt this on down to the floor from the inside or you not only made a nice box but allso a verry conveniant caryingcase for the guys with the sticky fingers
ARAMP1
New postPosted: Tue Dec 16, 2008 11:19 pm
570
Yeah, there's Dynamat behind it already. It will be bolted down using the stock seat mount/seatbelt bolts. Don't need this one being stolen.
KBLR ELF
New postPosted: Wed Dec 17, 2008 10:07 pm
1420
I think paris said it first but Ill say it to THATS HOT nice work I always get that stuff allover me when i work with it
NO REST FOR THE WICKED TILL WE CLOSE OUR EYES FOR GOOD
candy87ls
 Post subject: Re: Sub Box Build 1990 Silverado
New postPosted: Sat Jul 04, 2009 1:13 pm
160
that looks sick dude good job
New posts View first unread post Sub Box Build 1990 Silverado
ARAMP1
14
1140
candy87ls View the latest post
No new posts In Cab Sub Square Body Crew?
etcetera
709
Thu Sep 25, 2008 1:11 pm
etcetera View the latest post
No new posts Sub box for under rear bench seat?
[ Go to pageGo to page: 1, 2, 3, 4 ]
49
6269
Sun Feb 10, 2008 2:33 pm
EC_Dually View the latest post
