Post new thread Reply to topic  [ 15 posts ]
 Post subject: Attn: Audio Gurus
New postPosted: Fri Dec 19, 2008 5:16 pm
67730
Can anybody give me a wiring diagram for your basic stereo system?
My guess is that you power the head unit and then the head unit speaker leads go to the amp, then the amp goes to the speakers. Correct?
Do the amps have a separate power supply? I'm thinking so.
Obviously, I have no idea about this stuff.
Bowtiefan
New postPosted: Fri Dec 19, 2008 5:35 pm
150
I can help you with this one.
Most every head unit for the last umpteen years have the same wiring harness colors.
RED: 12V Switched ignition source
YELLOW: 12V continuous (always has battery power on it to save your clock and presets)
BLACK: A good ground
BLUE: Sometimes referred to as the power antenna wire or the remote trigger wire.
If you are not using the speaker outputs on the head unit, tape the ends of those wires so they cannot come in contact with anything metal. This will short the outputs on the head unit. Should you ever decide to re-use this unit with its on board power you don't want to short these.
The most common way to hook up an amp is to run a pair of RCA's from the back of the HU (head unit) to the amp (red to red and white to white). Next you will have to extend the BLUE wire I talked about previously all the way back to the amp.
To power the amp you MUST run a sufficient gauge wire to the positive side of the battery, terminating it at the battery with a fuse equal to the size of the one in the amp. You can ground the amp on a seat bolt most times with good results. THEN you run your speaker wires from the amp to the speakers.
Clear as mud? :lol:
Just think of it as a waterfall kind of, with the head unit being the top of the hill.
Here's a link to a decent diagram:
http://www.caraudiohelp.com/how_to_inst ... ar_amp.htm
PM me if you have any further questions!
New postPosted: Fri Dec 19, 2008 6:01 pm
67730
No man, that's perfect. That's exactly what I was looking for.
Thanks.
raymondsage
New postPosted: Fri Dec 19, 2008 6:06 pm
5850
:roll:
New postPosted: Fri Dec 19, 2008 6:52 pm
67730
What's the matter Ray? You bummed 'cause BF beat you to the punch?
You wanted to be the hero of the day and gain some notoriety by helping the Campy, huh Buddy. :wink:
Okay...here's your chance.
Suppose I wanted to add a little bump to the 'Burb with the following criteria:
1. I'm a Pioneer man and I like to keep it "all in the family" so-to-speak.
2. I like clean installs, which mean I like my stuff to fit in the factory positions. I don't mind moddin' stuff as long as it's not out of hand. Someting like this is as wild as I'd get-
http://67-72chevytrucks.com/vboard/atta ... 1213830614
3. Mrs. Campy gets pissed if there's a lot of stuff that takes up valuble grocery room in the back. I'm thinking one 10" sub would be sufficent, but it has to be a low pro install. Removability is a huge plus.
Impress me.
New postPosted: Fri Dec 19, 2008 7:13 pm
67730
Would this amp...
http://www.crutchfield.com/p_130GM5300T ... _and_specs
Be a good choice for this sub?
http://www.crutchfield.com/p_130TSW252R ... tml?tp=111
Doordragr
New postPosted: Fri Dec 19, 2008 7:40 pm
27080
keep the fuse on the power wire to the amp no more than a foot from the battery
Bowtiefan
New postPosted: Fri Dec 19, 2008 8:57 pm
150
^^ Good point too^^
BowtieCowboy
New postPosted: Sat Dec 20, 2008 2:04 am
3820
I still can't believe campy got a straightforward answer to his question that quickly...we must be slipping.
Smith and Wesson...the original point and click interface...
New postPosted: Sat Dec 20, 2008 8:31 am
49840
its cause a newbie answered it before any of us could respond to it.. :lol:
Bowtiefan
New postPosted: Sat Dec 20, 2008 10:08 am
150
Sorry! Is Campy the resident whipping boy? :lol: 8)
Bowtiefan
New postPosted: Sat Dec 20, 2008 10:09 am
150
BowtieCowboy
New postPosted: Sat Dec 20, 2008 10:55 am
3820
No ...it's just that usually the post gets whored up so bad it takes about 20 replies to actually get an answer.
Don't worry though, we'll forgive you this time.
New postPosted: Mon Dec 22, 2008 11:21 am
67730
Pfft!
You got a lot to learn, Son!
New postPosted: Mon Dec 22, 2008 1:12 pm
67730
So...seriously, no one has any suggestions to my other questions?
Fags.
New posts View first unread post Attn: Audio Gurus
14
433
